Results 1 to 4 of 4
Thread: 1st time turbo upgrade...i got Q's
    Default 1st time turbo upgrade...i got Q's
    i have a 96 talon Esi motor, and i want to bolt a turbo from a 93 motor i found .couple Q's, this is the first time im gettin my hands on a turbo. im taking it off a 93 dsm motor. would i be bale to use the manifold and all the neccissary parts off the 93 motor and bolt it on to my 96 motor? also will my motor fit into the 93 body?
    Boost User
    The 2nd Gen. NT's came with the 420A motor, which is shared with several Chrysler cars. The manifold from the 1st Gen. 4G63 wont fit. Check out:
    2GNT For more info on turbocharging yours.
    05 EVO
    I AM A SOCA WARRIOR TRINI4LIFE's Avatar
    C'vton
    If it can not fit your 96 are you going to sell it?
    thanx for the input. sell the 96 motor or the turbo 93 motor? i dun have the 93 motor yet. but i asked wat was wrong wit it just to make sure the turbo isnt messed, the seller told me the valve rods went str8 throught pistons. which is pretty fucced up. but if i dont get it ill pass on the info to you so you can take a look at it.
