- FS 4 brand new 10in subs
FS 4 brand new 10in subs;price edited
These are 4 10in brand new subs. only taken out of box for pictures. I have been talked into going a different route. so I don't need these.
also a hatch box for 2 10's sealed. goes to the buyer also
Specs:
160 oz. Double stacked Ferrite magnet
Oversized rubber surround
Power handling:800 Watts Peak, 400 watts RMS
Vented 4 Layer Dual 4 Ohm Voice coils
Diameter: 2.5" Voice coil
Nominal impedance: 4 ohms /per coil
DC resistance: 3.2 ohms each coil
Frequency range: 20 Hz-1.5 kHz
Fs: 41 Hz
Qts: 0.6360
Qes: 0.7209
Qms: 5.4047
Vas: 26L
Xmax: 11.9mm
Sd: 0.0346m
Mounting Depth: 135mm
Mounting Hole Diameter: 250mm
SPL: 86.54 dB 1W/1m
This driver will work best in a sealed or ported 1.0 cu. ft. or larger box
I'm look to get 225 obo. delivery we can meet halfway to save on money
here are some pics.
- You may not post replies
- You may not edit your posts
Forum Rules
