Results 1 to 20 of 20
Thread: Improved handling for my Teg
    Intugly tybalt6691's Avatar
    Default Improved handling for my Teg
    I have koni reds and neuspeed springs and want to stiffen up my stearing and tighten up my turns. What would you guys reccomend? I hear h-brace and rear sway bars. What is the best route to go down to improve the handling of my ride?
    Give me places to buy the equipment too.
    a track near you..
    Energy Suspension Polyurethane Bushings. ITR rear swaybar, Roll cage
    I need specifics what brand where to buy and approx cost. Cant go with roll cage.
    a track near you..
    Quote Originally Posted by tybalt6691
    Energy Suspension is the brand. summit has them for cheap around $120
    ITR stands for Integra Type R. Try ebay
    The bushings will tighten up the stearing?
    And the ITR rear sway bar does it matter if its an off brand?
    Is it a bitch to install the bushings kit?
    Jan 2003
    buy a set of sticky tires. simple as that. why do you want to stiffen up your steering and tighten up your turns? those mods don't make your car grip the road better. you don't want a roll cage, unless you want to bash your head in if you get into a small traffic accident.
    to sum it up, get a set of better tires, i'll start off by listing some good ones:
    kumho mx, falken azenis rt615, hankook rsz212s.
    edit: bushings are a good idea, but they're pain in the ass to install.
    roll cage, lol. Its obvious this guy just has a street car, he doens't need a roll cage. It will only make it more dangerous for him to drive his car. IA suspension advice is meh...I think the suspension forum was removed for a reason.
    Jan 2003
    Quote Originally Posted by PacoX
    maybe because it was jealous that the NWS forum got all the ricers' attention
    Daytona Beach
    type r sway bars are very different from gsr sway bars mount wise but make a noticible improvement.
    a track near you..
    Its one of the best ways to stiffen the chassis. Never said I would do it.
    I have an SE(LS). ITR sway bar and bushings will be my best bet?
    Senior Member 99SI's Avatar
    Jackson
    I have heard some very good things about frame locks. Korbach performance sells a kit. I think the site is Korbachperformance.com but I'm not sure. I have been wanting to put them on my car. The people that have put them on say it makes a huge difference in the handling. It makes steering extra sharp and eliminates the chassis flex up front. They are fairly reasonable for what they do and don't seem to be that tough to install.
    I've been noticing that I get body roll like crazy on the hwy on curves (scary, tailend wags). What are some simple & cheap things I could do. Opinions, how much of a difference does a lower upper & lower strut/tie bar make ?
    Jan 2003
    do you not read? tires are the only thing between your car and the road... chacnes are if you're asking this question you have less than decent tires, so No, tires are your best bet if you want to actually handle well, then some new bushings to compliment your new grippy tires.
    Jan 2003
    Quote Originally Posted by KevinT707
    waste of $. the hierchy of suspendion modding for a street car, IMO, should go like this ->
    good tires->new bushings, fix broken parts, alignment->good shocks->springs->sway bars should be last and should not be added jus because, they are used to tune the balance of the car->then whatever bars, cahssis stiffening you fancy.
    Ive got good Kuhmo tires brand new last week and would like to stiffen up the turning and cornering response.
    Jan 2003
    what kind of "good" kumho tires? the only street kumho tires I would consider good is the kumho mx, 711, 712s or whatever it is aren't really serious performance tires. But... if you have them and they are new and you don't want to sell them, and seeing how you already have new shocks, I would replace old/worn out bushings and get an alignment, you could probably check for some good alignment specs on your car on honda-tech or something. After that if you still feel the car rolls too much or understeer/oversteers then sway bars will probably do the trick. Again, you could probably find alot more good info on honda-tech.
    I have Kumho 711s & they are the worst, especially in the rain. My alignment is perfect also.
    Yeah man. Fr33way's Avatar
    North OTP
    Assuming your susp. is in good repair, upping the spring rates (or going to full coilovers) will cure any roll issues.
