Thread: 2 Gateway 15 inch lcd flat screen monitors
    lawrenceville
    Default 2 Gateway 15 inch lcd flat screen monitors
    2 gateway flat screen monitors brand new never used purchased for 270 a piece want 225 for each
    Specifications
    Agency
    Certifications Energy Star®, UL, cUL, FCC Class B,
    NOM, CE, TUV/GS, VCCI
    Brightness 250 cd/m2
    Colors 16.2 million
    Contrast Ratio 400:1
    Dimensions
    (W x H x D) 13.71" x 13.60" x 5.67" with stand
    13.71" x 11.32" x 1.97" without stand
    Display Stand Included (Tilt backward/forward adjustments)
    Electrical
    Requirements Normal operation: 40 Watts
    Off (power-save): 2 Watts
    100-240 VAC, 50/60 Hz
    Limited
    Warranty 1 year parts and labor
    Mount Compatible with VESA (4x100mm) compliant mounting solutions
    Panel Type LCD Active Matrix TFT
    Pixel Pitch 0.297mm
    Ports AC Power Input, Kensington Security Lock Slot
    Resolution 1024 x 768 (native and maximum)
    Response Time 16ms
    Screen Treatment Antiglare
    Signal Inputs Analog (VGA) – 15-pin mini d-sub VGA
    Digital (DVI-D) 24-pin DVD-D
    Tilt Yes
    User Controls Power On/Off Button, On Screen Display Menu Control Buttons
    Viewable Area 15 inches (diagonal)
    Viewing Angles 130º Left/Right; 100º Up/Down
    Weight 5.74 lbs. with stand
    lawrenceville
    IA MEMBER YokotaS13's Avatar
    saudi arabia
    they have 15 inch at walmart new for 159.00
    lawrenceville
    oka but this is not a wal-mart brand but thanx for the bump
    lawrenceville
    BUMP MAKE AN OFFER
    lawrenceville
    lawrenceville
