Results 1 to 21 of 21
Thread: Hood pins on a CF hood
    BMW_VW D_Land.rep!! EX-Svic's Avatar
    Default Hood pins on a CF hood
    where do i place the hood pins on a 94 civic Cf hood and how do i do this without messing up the hood,
    ALL CAPS JITB's Avatar
    you going to have to drill into the hood.. if u dotn want to do it. let a body shop do it. Its not too hard tho, but u seem like u shouldnt do it yourself.
    KEITH atlvi3tb0i's Avatar
    Clayton County
    don't do it
    aftermarket latches suck.. ive heard and seen 5 cf hoods fly up on ppls windshield. 12$ will save u a new hood/windshield.
    Gwinnett-Grayson
    i hate hood pins
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    yeah the latch used to work and now it doesnt and my hood stays open , im not a big fan of hood pins but i need them, Like JITB i dont want my hood flying all over the place lol ........
    woodstock, GA
    invest in some good ones like the key lock one if anything and you'll be fine
    www.wagenwerksatlanta.com
    Auto Collision & European Restoration
    920 Cripple Creek Drive
    Lawrenceville, Ga 30043
    678.407.8025
    Find a spot on the upper radiator support to put them, there may be existing holes somewhere...install the pin putting some sort of paint/nailpolish on the top then set the hood down so they mark the bottom of the hood. Drill the hole at those marks (or maybe a hair forward) then install the little plate on top
    Quote Originally Posted by exjnv
    yea those are little less noticeable, but they will rust over time. if u want or can get some cheap flat black paint and spray them black before u installt hem so they wotn rust. I had to put soem on the protege after my swap
    Quote Originally Posted by blacknightteg
    i hate hood pins
    Under the hood of my car...
    but yeah it's almost a must to have hood pins with a CF hood.. bad shit happens otherwise..
    Got Rice? 93dituneex's Avatar
    Newnan, Ga
    My opinion on hood pins are that they are only needed on off name brands of hoods like procarpartsonline.com hoods or some other hood you buy from a not-so-famous company. I have one from VIS and see no need for hood pins. The latch is very strong and doesn't seem like it will break. Since he is having problems keeping his hood closed period then hood pins may be a good idea. Just my though.
    sounds like a plan thanks for the advice.......Peace
    yeah i was thinking of getting some black ones and apply some clearcoat on them to keep them from rusting ....
    i depends on which one's you get i guess. i tried to paint mine black and the paint wouldn't stick so i left them chrome. they haven't rusted yet and i've had them for 3-4 years now.
    the key type are definately the way to go...i'm very happy with mine.
    listen to the tips so far on the install. one trick is going to be that you'll have to bend them so they will be perpendicular w/ the hood. therefore, you'll probably have to bend them forward a little to work the contour of the hood and so the latch will work properly.
    also, apply some masking tape all over and around the area you'll be drilling out. this helps to keep the glass from cracking/chipping and spiderwebbing.
    Thumbs up
    DONE i got these key lock carbon fiber hood pins from NRG they look str8 on the hood all you notice is the little chrome niple, Not bad looking at all , Thanks for the advice ........Peace
    Quote Originally Posted by EX-Svic
    post up pics after the install..
    Will do , just let me get my digi cam by this weekend....Peace
    here it is,
    Attached Thumbnails Attached Thumbnails -carbon-fiber-hhood-jpg   -bolts-jpg
    looks good
    THNX.........Peace
