Results 1 to 14 of 14
Thread: Bseries problem
    ZERO sir2hb's Avatar
    L.B.C (little bitty calhoun)
    Default Bseries problem
    I am having a problem with the lock nuts on the valve they keep comeing loose
    does anyone know if these is a common problem
    and what is a recomended fix
    I never won any spelling bees
    Horsepower looks good on paper, Torque wins races.
    ur valves are tapping if so try adjusting them
    I love Boost!
    Yes the valve is tapping because the lock nut is coming loose this is the 2nd time it has happen
    hello anyone
    MY BAD U SHOULD HAVE PM ME BUT YEA IF U ADJUSTED THEM ALREADY N IT KEEPS DOING IT THE VALUES ARE FUCKED UP
    I love Boost!
    yea the valves are not fucked up they are fine
    Bender A. Rodriguez
    Macon
    Take the nuts off, clean the stud and the nut with some carb cleaner and put a small amount of blue locktight on the stud. I've had a few motors that don't want to stay tight at sustained high rpms and this always fixed it. Just don't use red or you'll never get them off. It also doesn't take alot, one good drop is really all you need.
    Ryan Reynolds
    Quote Originally Posted by Cool Cat Racing
    exactly what i would reccommend. I hope the follower is not stripped causing the stud piece that rides on the vavle to move which would cause the nut to back of also. When u do the locktight thing ull find out bc the stud and the nut will try to come out. Good luck man
    Thank you cool cat finally a real answer sounds good to me I will do that and thank you btec too
    Hwy 315
    ...why don't you try putting the correct amount of torque on the nuts.... (14 ft. lbs)
    [/URL]
    Jesus Christ is my Savior
    You know I never thought of actually torque them with the actual torque spec
    Oviedo, FL
    QFE!
    DC5-R
    Gwinett
    Quote Originally Posted by hatch77
    Quote Originally Posted by Type-R
    QFE!
    what is QFE?
