Results 1 to 28 of 28
Thread: SR20DET build opinions
    TopSecret
    Cobb County
    Default SR20DET build opinions
    no
    Coming Back...................................
    Supraforums.com
    stockbridge
    none,u should give me those parts. rry, nice setup.
    Certified Gearhead dm1995's Avatar
    Ga
    sc-61
    :idb: 95 nissan 240sx SR20det 2002 VW passat 5spd 1.8t
    "THAT AIN'T RIGHT"V8 OWNR silviadriftr's Avatar
    IN THE PADDED ROOM NEXT TO BTLFED
    Which step 2 hks cams??? 256, 264, 272???? Is this going to be for street or strip? Bottom mount stock location turbo or do youplan to do a topmount with an aftermarket manifold??? These are key questions that should be addressed when trying to determine what turbo you should run.
    Mainstream Performance
    Home of Turbo Dave Fabrications
    2JZ TDF Built 240SX SOLD
    My RHD TDF Built SR20 FOR SALE
    record holding-473whp sr20
    stock cams and bottom end
    TopSecret
    Cobb County
    272 cams, top mount turbo with aftermarket manifold. More strip than street
    Supraforums.com
    Quote Originally Posted by Prophet180
    The sc-61, turbonetics 62-1, or garrett gt35r are the most common setups with either a .63 t3 ar, or .58 t4 ar, or a .72 t4 ar are the most common for theat setup.
    im with sliviadrftr, he know a lil bit bout turbo srs cars.
    In the Fucking A
    I think your about to waste alot of money on a setup you dont need. How much power do you want to make and what kind of engine management are you going to use to tune it.
    I fucked İhris's mom
    HIV+ HalfBaked's Avatar
    Quote Originally Posted by Big Baller
    In his list he has the emanage listed as a piggy back and from the isting of the 272 step 2's and the 740cc injectors it looks like he is shooting for the 450-550whp range.
    Why would it be a waste of money?
    Smackyaselfville
    I'm now thinking of going with either the AEM EMS or the Apexi Power FC which is best, and 850cc injectors.
    Project Vox has begun
    Turbobricks.com member
    GeckoSquad
    Quote Originally Posted by boosted_nonv
    AEM is a little more expensive but well worth the money for the control you get. Power FC has no where near the options of an EMS unit.
    Get the e-manage ultimate.
    im gonna say aem, the interface and tune ability is better than the pfc.
    Certified Gearhead run4cover's Avatar
    I wanted to know what size turbo should I use with this setup:
    CP Pistons (9:0:1, 87mm)
    HKS Piston Sleeves (87mm)
    Eagle Rods
    HKS Valve Springs
    HKS Stage 2 Cams
    HKS Adjustable Cam Sprockets
    Crower Titanium Retainer kit
    HKS Rocker Arm Stopper kit
    HKS Fuel Rail kit
    HKS Fuel Pump
    Nismo 740cc Injectors
    HKS 2.0 Metal Head Gasket
    HKS Oil Cooler kit
    Supertech Valves
    Tomie Valve Guides
    Greddy Intake Manifold
    Q45 90mm throttle body
    Z32 Mass Air Flow Sensor
    Greddy Front Mount Intercooler kit
    Splitfire DIS Coilpack kit
    HKS Wastegate
    Top Mount Exhaust Manifold
    Greddy E-manage
    Greddy Pulley kit
    Nismo LSD
    Exedy Clutch
    One Piece Aluminum Driveshaft
    Cusco 10.56 Flywheel
    HKS CatBack Exhaust
    well...we need HP goals to suggest a turbo....that's a basic engine build....a rather expensive one at that. I have a few questions about your selection of parts...first, what is an HKS 2.0 head gasket? that isn't a 2mm thick headgasket is it? If it is, what's the purpose of using 9.0:1 compression pistons? Sr's are 8.5:1 already...why would you lower it further. Are sleeves necessary for 87mm pistons?
    It looks like you made this shopping list from a super street magazine...trust me, I'm not hatin, but you either are about to waste alot of money, or you have already. Why a cusco flywheel? Exedy sells lightweight flywheel/clutch assemblies (I have one in my s13; 6-puck with flywheel)...i mean, since you want an exedy clutch anyways.
    HKS cat back? I'm guessing it's the hyper....I recommend Blitz Nur-spec....better sound/equal or better hp gains. HKS wastegate? Tials work fine, and are less expensive. And I'm guessing that top mount manifold would be a full-race $1000 manifold, huh?
    Here's a suggestion...nix some of the racer-boy stuff and buy some less expensive counterparts (you're paying for name on alot of that stuff), and do some head work (polishing and porting) with some of that money you have saved....that would help make some usable power for whatever turbo you decide to use....my vote for a turbo goes to a TDO6-25G (mitsubishi turbo).
    Just an example of feasable counterparts to your mega dollar parts...
    HKS fuel pump-----walbro 255lph, or 300zxtt fuel pump
    Cusco flywheel-----fidanza, exedy, jwt, jun flywheel
    Greddy FMIC------ebay fmic kits...search, there are certain ones that work exceptionally well.
    HKS fuel rail-----what's wrong with the stock fuel rail? I have 850cc injectors in mine.
    z32 maf------your limit is 500rwhp...select the quickest spooling turbo that will get you there.
    1 piece aluminum driveshaft-----you getting this for weight savings, right?
    Now, If your gonna do a big money setup like that, you forgot an adjustable fuel pressure regulator, an oil catch can, koyo radiator and electric fan, sub frame bushings, blah,blah,blah......fact is, you can build a comparable setup with half the $$$ you're about to spend....but, if you got it to spend, spend away.....matter of fact, you can write me a check for doing research for you
    Always startin new $hit
    [IMG][/IMG]
    TopSecret
    Cobb County
    I'm aiming for 550-600whp. And all the other parts that you mentioned are part of the build also I just forgot to mention them, and what other feasable counter parts do you suggest. And I'm not going to be using a mass air flow sensor now.
    Supraforums.com
    that was pretty much it...I mean, I was just trying to save you some money. I would go with the previous guy's reccomendations for a turbo, because he seems to have more experience with different turbos with sr20's than I do. I just like the mitsubishi turbos, they support alot of HP for their physical size. Everything else that I can think of is pretty much covered between mine and your list.
    You should have a pretty mean car when it's all said and done. Good luck , and enjoy.
    [IMG][/IMG]
    In the Fucking A
    If your shooting for that much power, Ditch the cheap eagle rods and get some pauter or carrillos, or maybe olivers.
    Most of the parts you have listed are nice parts but alot of them are uneccesary or, just plain overly expensive. I have a full race manifold, it looks like jewelry if you get it polished.
    Good luck
    Matt
    yeah, for that HP level, you'll want to go the MAP/ standalone route...I have no idea which is best, because I have never used any (eventhough I have a power fc for an s14). I have similar goals (horsepower wise), but my main thing is to do it on a stock bottom end (and have it last). I'm shooting for 400rwhp on pumpgas, and 500+ on methanol and pump gas....haven't full decided on the turbo yet, but the precision pt61 looks to be the one, it's a full T4.
    I also plan to have my ecu re-tuned to where the airflow values are halved.....so that I can run two z32 mafs, and not have to go standalone.....it'll get me past the 500rwhp barrier. This has already been pioneered by JWT on the 300zxtt...I had that setup (dual pop) on my 300zxtt, and it worked great, I don't see why it won't work on an sr.
    I guess you can call my build a high HP budget build. I'm only using what I deem necessary to get to my goals reliably.
    *850cc denso injectors
    *z32 maf (x2 for later higher hp)
    * tuned ecu
    *255 walbro fuel pump
    *greddy knockoff intake manifold
    *SSA top mount T3/T4 manifold and 38mm wastegate
    *3" turbo back exhaust
    *FMiC
    **272/272 Toda cams 10.5mm lift (still on backorder)
    *electric radiator fan
    everything with an * next to it is on the car now...chances are nothing else (power wise) will go on the car. The only thng I know I will change/add is the turbo, and I will add an alcohol injection kit.
    Right now, I have an ssa bottom mount manifold on the car with a pulsar gtir t28 running....it makes 290rwhp and 258rwtq @ 15psi.....this turbo can be pushed to 18psi on 93 octane (I just never bothered to turn it up from where I had it when I ran my stock t25) the stock t25 made 237rwhp and 255rwtq @ 15psi.
    The turbo I have right now is a T3/TO4E...57 trim, .50 a/r compressor and .63 a/r, stage III wheel turbine. I'm hoping to make ~350rwhp at the same 15psi with this turbo. I'm supposed to be putting it on this saturday, so I should have dyno numbers within a few weeks....then it's time for the pt61 (or whatever big turbo I finally get).
    [IMG][/IMG]
    In the Fucking A
    I have a brand new PT 61 I will sell you cheap, I decided to go bigger on my supra
    TopSecret
    Cobb County
    How much for it?
    Supraforums.com
    In the Fucking A
    Okazaki IronEagle's Avatar
    On the dyno
    Damn that is going to be tight when it is ready to roll.
    TopSecret
    Cobb County
    Just came in today
    And does anyone know Turbo Dave's e-mail, importatlanta name, or phone number?
    Supraforums.com
    stockbridge
    nice motor!!! woop. aare u gonna build it with all those parts before installing it? shit will be tight.
    TopSecret
    Cobb County
    Yeah, and still do a little to the motor that's in the car at the same time, that why I'm tryin to get in touch with dave,
    Supraforums.com
    stockbridge
    just call mainstream, they work with him so they should know. (vteckidd)
    Yeah, what he said. Dave is contracted through MSPi now so just call and talk to Mike. 678-567-9384
