Results 1 to 2 of 2
Thread: FS-JL AUDIO 500/5 AMP
    Atlanta GA
    Default FS-JL AUDIO 500/5 AMP
    JL AUDIO 500/5 AMP THE AMP HAS BEEN BENCHED TESTED AND RADIOACTIVE, AND ALL IS GOOD....
    HERE IS THE SPEC'S ON THE AMP......
    • Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
    • Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm(11V-14.5V)
    • Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
    • THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
    • S/N Ratio (F&R): >108.5 dB below rated power S/N Ratio (Sub): >95 dB below rated power
    • Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
    • Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
    • Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
    • Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
    • Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
    • Differential-Balanced Input Topology: (3 pairs of inputs)
    • Front Crossover: fully-variable (50 Hz-5 KHz), selectable- slope BP or HP (12 or 24 dB per octave)
    • Rear Crossover: fully-variable (50 Hz-5 KHz), selectable- slope HP (12 or 24 dB per octave)
    • Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
    • Preamp Output: 2-channel (full-range or LP)
    • Bass EQ: Variable boost up to 15db
    • Infrasonic Filter: defeatable 24dB/octave at 30 Hz
    • Left minus Right Ambience Circuit: ambient effect for rear channels
    • Front and rear speaker output connections: accept up to 8ga. wire
    • Dual mono subwoofer output connections: accept up to 8ga. wire
    • +12V and Ground connections: accept up to 4ga. Wire
    • Dimensions: 19.7"L x 9.25"W x 2.36"H
    AMP HAS A FEW SCRATCHES, BUT THATS ALL..
    $400....ok I will do 350....and thats the lowest
    93 Carbon-Fiber EG Hatch
    Built B16 w/ Type r Tranny LSD 4.440
    13.67@105mph All Motor
