Results 1 to 31 of 31
Thread: FS: glock model 17 & accessories
    in the dark...
    Default FS: glock model 17 & accessories sold!!!!!!!!!!
    Due to recent occurences, i've grudgingy decided to sell G.I.N.A . bought almost a year ago, it has less than 1000 rounds through her. she's been kept clean and in her box.
    things that i'm giving with her: hardshelled box, 2 10rd mags(fully loaded), 1 17rd mag(fully loaded), glock factory reloader, glock factory bore brush, last remaining 100rds of hollowtip ammo. molded FOBUS holster(lefty).
    UPDATE!!
    GINA NOW HAS A NEW HOME. thanks to the buyer. you will have plenty of good use from her!!!!!
    imma miss her (sniff, sniff)
    MAKE: glock
    MODEL: model 17
    Serial number: FAV129US
    CALIBER: 9mm
    A.K.A. GA Teg
    Jun 2001
    Behind the lens
    NO, why you gotta sell GINA?
    www.ATLphoto.net Myspace
    Everyday im HUSTLIN'
    atlanta,ga
    NOT GINA!!! nOOOOOOOOOOOOOOO
    in the dark...
    i know !! well money got a little too tight. lost job and i gotta let something go in the meanwhile. i plan on buying another one after i get the boat steady. but for now, i've got to let her go......
    hondaisdabest
    would you sell for 300?
    in the dark...
    no less than 375, less than 1 year old, less than 1krds, all accessories, including ammo. she's a great gun. paid her more attention than my girlfriend(j/k). never dirty, never abused.
    1979 Civic Cvcc Saung's Avatar
    Tucker
    Hi, is this the model which can be shoot under water? No safer on her, right? I want the gun, but I'm lafraid my kid might get to it? That's my worse nightmare, but let me think about it since is a great deal.
    in the dark...
    Quote Originally Posted by Saung
    i was telling the other guy i wasnt going any lower than $375(thats at the absolute lowest,) 'cause that would be a huge cut for a gun that is otherwise in mint condition. 400-425 i'd let it go right now. with everything mentioned.
    in the dark...
    Hi, is this the model which can be shoot under water.....
    to answer that question, just about all glocks can be shot near water but...
    Although you may install the maritime spring cups on any Glock model, *only* the Glock 17 was designed and intended to use the modified spring cups for aquatic firing -- and only then using 9mm ball ammunition to remain within acceptable pressure limits. The foolhardy who insist on living dangerously must keep several things in mind: The Glock 17 must be fully submersed underwater. There must not be any air left within the pistol as the muzzle is pointed towards the surface of the water after submersion to allow the air in the barrel to escape. Use only full metal jacket, ball-type ammunition because the water within the barrel can spread a hollow point out within the barrel upon firing. This increases the bearing surface of the bullet to the barrel and could catastrophically increase pressures. Even if the barrel doesn't burst, the expanded bullet would get even bigger upon exiting into the water and would slow down very quickly while tumbling. Accuracy would be terrible.
    The Glock 17 may be equipped with an optional set of maritime spring cups for use in water environments. Maritime spring cups are not intended for submerged firing, but for surface use by special ops teams who operate in and around water. The maritime spring cups are two small parts within the firing pin assembly and are not included on any Model 17 sold by Glock (civilians can only get them through 3rd parties). They insure that water can pass by the firing pin within the firing pin channel, thus preventing the creation of hydraulic force within the firing pin channel -- which would slow the firing pin down, causing light primer strikes. With the special cups, the action will cycle reliably while submersed, if a little bit slower. NATO specification ammunition (such as Winchester's Ranger RA9124N) with waterproof sealed primers and case mouths is recommended.
    in the dark...
    bumpers for a good gun.
    NorthSide
    the fuck u wanna shoot it underwater for??
    nice gun.
    get the 30 rnd extended clip for it, pretty badass
    atlanta,ga
    you said less than a 1000 rounds been through that gun. I can buy that same gun for $300 with that many rounds shot through it. Maybe even cheaper. I'll find out next week when I go to the gun show. But 9mm with that many rounds are not that expensive. But then again it is a a glock.
    375 seems fair market price if it has a few accessories like extra mags.nite sights, or adjustable sights...i'd love to have a glock nine to sit next to my glock 22c 40cal..they are great guns but atif is right..gun shows have them for 300....and if u are savvy enough..a "new" glock factory re-pop can be had for 400...
    Is yours a new style frame with finger grooves and a sight rail?
    Free bump for a sweet toy
    atlanta,ga
    true..i didnt take the accesssories into consideration..
    wish it was a 19 :/
    in the dark...
    Quote Originally Posted by bigjussin
    that it is. it has the handle with the molded finger grooves and the sight rail for mounting accessories like lights or those big ass cumbersome lasers. i was gonna get the slide chromes and instal the internal crimson trace laser that replaces the recoil rod, but at this point in time i wont be able to do that. i'll just buy another one(glock) later on this year and out fit it the way i wanted to do this one.
    in the dark...
    Quote Originally Posted by phongy
    nice gun.
    dude prollly want to see if the myth was true....but i wouldnt recommend anyone try that shit! it's too risky. and like you said, why would one want to shoot their gun underwater ? this aint SOCOM or METAL GEAR SOLID. i dont see any situation in our civilian lives that would cause for one needing to shoot while submerged.
    Memphis, TN
    is this 3rd gen glock?
    i have a glock 19 and glock 17. they are good guns.
    Blah Blah Blah!
    in the dark...
    yeah. i think its a 3rd gen.
    if i could justify the cash..i'd snatch it up
    in the dark...
    bumpers !!!!
    Joker Performance 1 Neon StreetSweepn's Avatar
    Austell
    it is a REALLY nice gun just a little out of my price range ill stick w/ my ruger p89 9mm for now
    2003 Subaru wrx wagon
    1996 Dodge Neon
    1998 Mustang GT
    1971 Suzuki GS550L
    Cyanide & Happiness @ Explosm.net
    in the dark...
    ^^^^what's your range ??
    Team Korupshun DamnDisLaOsBoY's Avatar
    Lawrenceville, Ga
    trade a black .32 beretta.. and 100? berettas are expensive
    in the dark...
    NO SIR...THNKS THOUGH.
    right behind you...
    goin to the gunshow next weekend, if i don't pick up something there i might still be interested.
    Fock Yes!! DurtySpeed's Avatar
    Cartersville, Ga.
    Whats the age to buy a pistol? Is there a website somewhere that shows all the rules on transporting one? Like keeping it in sight in the vehicle, etc.
    right behind you...
    21 to buy w/no felony convictions. if u don't have a conceal weapons permit then u can transport it on your passenger side seat or glove compartment loaded i believe, but NOT under the seat or in your trunk, unless of course then it's unloaded and in its case. just google ga gun laws for all the details.
    Fuk Who U B!
    Northside B
    Yep, Bump for a Hella Nice Gun man.. I love it!
    in the dark...
    absoludely is correct.
    in the dark...
    bumpers.....lol!!
