Results 1 to 24 of 24
Thread: FS: Nitro RC car
    All Motor BlackDubs's Avatar
    Atlanta,GA
    Default FS: Nitro RC car
    Duratrax Street Force GP2. 3 months old
    Comes with 1 controller, 3 sets of wheels (1 is still new w/tires), 3 bodies (Corvette,Civic Si, GP2 body), body cutting tools,2 glow starter,fuel bottle,aftermarket dynamite exhaust and I have a box with a traxxas nitro car for spare parts,spare traxxas.15 motor,extra controller-servos-receiver-screws-shocks-crystals-exhaust,fuel lines and 1/2 gallon nitro fuel. It does 50+ Mph.
    Its 4WD and one of the 2 pulleys is messed up, it still runs but just needs 1 new pulley, and I dont feel like ordering it (only $5 dollars) since I never play with it anymore. Open for trades for 92-95 Civic hatch parts and car related items or will sell for $200 obo.
    Specs:
    FEATURES: Chassis: 1/8" (3mm) thick 6061 T-6 aluminum
    Drive: Four wheel drive
    Drive Type: Three belt
    Engine: .18 (3.0cc) Duratrax by O.S. Max pull-start engine with ball-
    bearing supported crankshaft, heavy duty conrod and two-needle
    rotary carburetor
    Exhaust: Aluminum tuned pipe with header
    Radio: Duratrax by Futaba 2-channel pistol grip with servo reverse,
    steering and throttle trims, adjustable steering rate, LED
    indicators and AA batteries, charge jack for optional NiCd
    batteries, DTXP4010
    Fuel Tank: 2.5oz (75cc) flip top cap
    Clutch: Two nylon shoes with 16 and 19 tooth steel clutch bell
    Transmission: Two-speed
    Ball Bearing): Full set included, 16 total
    Shocks: 4 large volume oil-filled with coil-over spring
    Main Gears: 42 and 46 tooth, constructed of nylon
    Gearboxes: Open front and rear
    Differentials: Ball type (with 12 balls) front and rear
    Brakes: Single composite disk
    Tires: Proline Road Rage, inner diameter 1.9" (48mm), outer diameter
    2.5" (63mm), width 1" (25mm) with foam inserts
    Wheels: Proline Wabash 10-spoke chrome touring car, outer diameter
    2-1/16" (51mm), inner diameter 1-7/8" (45mm), width 1" (25mm)
    Body: Highly detailed 2-door touring car painted and trimmed
    Bumpers: Reinforced, front
    Suspension: Double wishbone
    Camber Tie Rods: Fully-adjustable, camber describes the angle at
    which the tire and wheel sit when viewed from the front
    Toe-In: Fully adjustable, toe-in describes the angle of the front
    tires as viewed from the top
    Steering: Bell-crank
    Servo Saver: Included
    Fuel Bottle: 8oz (250cc)
    Glow Starter: C-size with battery
    INCLUDES: Duratrax Street Force GP2 with oil-filled shocks, .18 (3.0cc) engine
    painted body & wing, tires, foam inserts, wheels, radio system,
    16&19 tooth clutch bell, 42&46 tooth spur gear, instructions,
    fuel filler bottle, glow starter, C-size alkaline battery , 12 AA batteries, instructions, parts list and decal
    sheet
    REQUIRES: Misc. Items: building and track equipment
    Fuel: 2-cycle glow fuel with 10%-20% nitromethane, 16% lubricant-
    Most of the fuels we carry meet or exceed the lubricant content
    required for optimum performance and maximum engine life. In the
    past, the conventional lubricant content used in fuel was 18%. But
    with new advanced technologies, fuels like Red Alert and O'Donnell
    for example, have a better quality of lubricants even though the
    percentages of lubricant content are lower. These high-tech
    lubricants provide exceptional cooling and protection.
    SPECS: Vehicle-
    Length: 16.5" (435mm)
    Width: 7.7" (195mm)
    Height: 4.6" (115mm)
    Weight: 3.1 lbs (1.4kg) approx.
    Wheelbase: 10.1" (255mm) wheels on-center front-to-rear
    Tread- Front- 6.5" (165mm) wheels on-center side-to-side
    Rear 6.6" (168mm)
    Front Track: 7.3" (186mm)
    Rear Track: 7.4" (189mm)
    Ground Clearance: 0.47" (12mm)
    Gear Ratio: 2.6:1, 2.4:1
    Body-
    Length: 16.7" (425mm)
    Width: 8.3" (210mm) at rear wheels (widest point)
    7.7" (195mm) behind from wheels (thinnest point)
    Height: 4" (102mm)
    Upgrades over the original Street Force include:
    .18 cu in (3.0cc) engine (20% larger displacement)
    Improved suspension geometry
    More mounting points for shocks and camber links
    New ball diff with 12 balls instead of 8
    Proline Road Rage tires mounted on chrome Wabash wheels
    Aluminum shock towers
    Stronger front bumper
    Lighter, thicker and stiffer chassis
    New front bulkhead for better diff protection
    Redesigned fuel tank with lower center of gravity
    Larger volume shocks that hold more oil
    New heavy-duty body mounts
    CV front drive shafts
    New body and trim scheme
    Fuk Who U B!
    Northside B
    Bump for a Deal... I love R/C'!!! Bump for a Great Seller!
    i4 Garage Bitch!!!!! Jdmvtecy0's Avatar
    only if i had money.. I would love to get into
    nitro rc's agian. Good deal
    ALL_Motor_Slammed_DB :jerkit:
    Atlanta,GA
    Barrett Parkway, GA
    if you still have this for sale in a couple weeks...i'll prolly buy it...i want another nitro along with my RS4
    what kind of trades are you looking for
    Please post more pics Look through my thread to see if anything interests you. LMK
    Atlanta,GA
    Quote Originally Posted by aaronfelipe
    what thread?
    Quote Originally Posted by DBtwo
    what thread?
    All of my threads. See if anything interests you.
    Dec 2003
    Lawrenceville, GA, USA
    I will give you $200...
    Atlanta,GA
    Bump
    Fuk Who U B!
    Northside B
    DAMN FOR A HELLA DEAL!!! I wish I had the money..!
    no corey you already have one i want it this is nick from school
    Atlanta,GA
    bump for serious offers.
    Atlanta,GA
    Atlanta,GA
    Fock Yes!! DurtySpeed's Avatar
    Cartersville, Ga.
    Trade for some tools? See sig.
    Buford
    does hatch parts include stereo stuff?
    Atlanta,GA
    Quote Originally Posted by connect
    Those are some nice set of tools. But I only need complete socket/rachet and wrench tools.
    Thanks though.
    Atlanta,GA
    I dont really need stereo equipment. But what you got to offer?
    Buford
    two ten inch memphis audio M-class DVC in a box?
    Atlanta,GA
    I have no use for subs right now.
    You gonna get back to me?
    Atlanta,GA
    I didnt see anything that I need.
