Its advised that you run tubes, but some people don't and don't have problems Just wanted to see what the average is of people running slicks with no tubes to ones with them, especially people making over 350hp. Thanks in advance
that really just depends on the type of slicks you wanna use. i've never heard of anyone using tubes in any modern type of drag slick, only old school bias ply stuff.
I was planning on getting some MH slicks. I'm not sure if they're bias ply though
dunno how much it helps, but after reading up a bit the only M&H tires i see that recommend using a tube is the "cheater slicks". the racemasters (the ones i've normally seen) have no mention of using a tube.
No tubes here on S3 w/toys
2005 Dodge Neon SRT-4
wow S3? What times and 60' have you gotten so far?
no tubes on mine
You dont have to use tubes in the slicks that recommend tubes but you just cant drop the tire pressure too low. Especially in wrinkle walls! And the tire size also affects your ability to drop pressure with no tube. Hope that helps
R.I.P. Booga
"GA sucks the power out of cars w/ magic."
6psi of air, no inner tube...Never had a problem, yeah they leak out eventually but not in one event...
Originally Posted by Mr. KiDD
Just did a 12.2 @ 116 and a 12.3 @ 117 earlier at Steele. 1.8 60 ft. That track is kinda scary (gravel and uneven pavement a bit past the 1320' markOriginally Posted by pinoyboy
) so I didn't punch as hard as I could have. Hoping to break 11's at Silver Dollar or Commerce.
nice, whats your setup? I'm hoping for low 12s this year if I get those 24.5/8.5/15
That size slick is what I'm running on a set of PT steelies. Here is my current setup:Originally Posted by pinoyboy
Mopar Stage 3 with toys
AIS FMIC
LFS 60 mm TB
Dasmopar ported intake manifold
Maxxfab S3 O2 housing
Maxxfab DP w/ cat
Mopar exhaust
Mopar drop in air filter + wires
NGK 4306
Maddog STS
cool man, Nice and simple. My setup I'm gonna run will beOriginally Posted by Member31410
100 shot
water/methanol injection
slicks
Stage 1
3" O2 CTI
3" DP and Exhaust
LFS 60mm TB and adapte
AEM CAI
180 stat
Walbro fuel pump
Agp custom wires
If I do anything more to my car, it'll just be a head job and maybe W/I. With a head job, I should be running consistent 11's. Like you said, this setup is pretty simple and requires zero tuning.
What size slick and rim, and what brand slick? And its not about the air leaking out its about you spinning the tire right off the rim.Originally Posted by anothaRRR
R.I.P. Booga
that is true but, the slicks still spin even with 7-8 psi depending upon the traction you get. if its spinning then you would need to bead it.Originally Posted by MidnightAuto
we're running welds 13x8 and 15x10
slicks are:
MH 25x8.7x13
MT 26x8.5x15
MT 26x10x10
none used tubes. didnt bead the 15's until recently..... 6-7psi
94 Supra= 500rwhp
24.5x8.5x15 M&H slick on Bogart drag wheels...No I meant they leak after a while from sitting, after every run you actually gain like 2psi of air from the burnout and the heat....Originally Posted by MidnightAuto
Mine leaks too. I mark my wheels and slicks to see if they move but so far, it hasn't yet on six total passes.
i got mt 20x8x14 with out tubes on a set of bogarts and they hookup great on the street. the only down fall is they leak and go flat within a couple days
