Results 1 to 15 of 15
Thread: Gas ?
    All Motor.. For Now
    Sanford, NC
    Default Gas ?
    Alrgith so i have been using regularunleaded for a while and was wondering does preium gas octan 89 actually that much better for ur car then regular. i know stupid ? but not sure like what it all does better. thanx
    ♥Chuckster's Wifey♥ Ms Dollar's Avatar
    Kennesaw, Georgia
    it depends...
    ~Val for President~
    ~RIP Leisa - You will be missed~
    sandy springs
    personally i would only run premium in an sr20
    All Motor.. For Now
    Sanford, NC
    my car is stock minus a cai and new clutch but just curious thanks
    'Round These Parts
    haha Anything less that premium in a boosted car would mean problems.
    Anyway in your case, your car was designed to burn regular unleaded. Couple tanks of premium per year wouldn't hurt (clean out the system since 87 forms more deposits)
    Even mid grade every now and then would be fine.
    but you're fine with REG.
    Leisa and S. 4 Life NM?
    Aug 2001
    Charlotte, NC
    Unless the car is designed to fire on 93 Octane you are wasting your money. It will not make any difference on your motor if it doesnt require ot or if it cant fire the 93 like its meant to.
    '15 Chevy SS
    '16 K7 SXL SWP
    I shave my legs... dartingd's Avatar
    on the bike
    hmm...i have an h22 which i don't know the recommended octane for...usually in hondas it's reg. isn't it...after about a month of getting different octanes 2-3 at a time to make sure, i came to the conclusion that medium actually lasts longer and costs less than regular...premium lasted the same amount of time as medium...
    PSN SN= dartingd
    Dont use anything more than regular unless your vehical manual says so. This point has been pounded repeatedly on the internet. You will not get any benefit running anything but 87 octane regardless of any year car that was not designed or intended to use it. Speaking for my car and I might speak for some others as well, with the new style PCM (late 99) have adaptive timing trim. (Well better then 98+ cars anyway) However it is not adaptive ABOVE the timing tables. It is designed so that the PCM compensates for variations in fuel quality in a range right around 87. (Roughly +/- 2)
    The only other benefit to running, say 89 octane, in a car programmed for 87 is if you have pinging from carbon buildup and dirty manifolds. However this need for higher octane actually lowers performance and mileage. (i.e. efficiency) While 89 octane masks the problems the real fix is cleaning out the carbon and your manifolds.
    Aug 2001
    Charlotte, NC
    Quote Originally Posted by speed
    I run 93 in the type r
    The car is meant to be run on premium. The manual even says that
    '15 Chevy SS
    '16 K7 SXL SWP
    on the bike
    hmm...what are u supposed to run in an h22? if i can run reg. and it not screw up my mileage much, i will...i'm only getting like 22mpg right now anyways...
    PSN SN= dartingd
    Im sure its premium. I knew someone with an H22 prelude and read their manual one time and it indicated running premium.
    on the bike
    NOOOOOOOO....that's expensive! lirl, oh well..guess i'll switch next tank...
    PSN SN= dartingd
    Lawrenceville, Ga
    I hear if you run Kerosene that it will have you 20 more horses and burn at 45 MPG!
    2006 CBR F4i - (Sold)
    2007 Lexus IS - (Sold)
    2006 MazdaSpeed 6 - (Sold)
