Results 1 to 13 of 13
Thread: i have an amp problem
    Senior Member WhiteMike's Avatar
    NE Atanta, GA
    Default i have an amp problem
    i have a question if you fuse blow everytime you put it in the amp whats wrong with the amp?
    the fuse in line on the power wire or the fuses in the amp
    NE Atanta, GA
    the fuse on the outside
    Johns Creek
    If it is the fuse at the battery on the power wire, first disconnect the power wire from the amp and install a new fuse. If it blows, you have a short in your power wire. Check at the firewall (or doorjam) first, a lot of times installers do not install the power wire correctly and it leads to chaffing off the wire.
    If it does not blow, check your ground wire connection to the body of the car. A poor ground can cause the amperes rise - and draw more than the fuse is rated to handle.
    Start with that. There are more thing you can check, but first one question. Is the fuse blowing immediately when you stick it in the fuseholder, or is it after you turn on your stereo, or is it just gradual. It the fuse disformed, like it got hot gradually and started to melt, or does it look like it just quickly popped?
    Devin 5thgcelica's Avatar
    snellville
    from the information i knwo about his car.
    its the actual fuse on the amp itself. and from my understanding it blows right away.
    if its the fuse on the amp itself that keeps blowing then i would say your amp is bad!
    formerly ATLS2K .....'s Avatar
    in your womans meat curtains
    We have a repair tech here at AUDIOPRO he is here on fridays and saturdays ... he most likely fix it for a good price...
    --TEAM FUCT OG--
    07' moomba outback v
    02' Xterra
    01' IS 300
    down the yellow brick road
    Maybe a bad ground wire?
    if its the fuse in the amp there could be a short inside check the wires make sure the positive isnt touching the case. what brand is it? some cheap ones just crap out al the time i have seen it happen to some pyramid amps
    NE Atanta, GA
    rockford fosgate the new ones
    Senior Member Kelly_Rene's Avatar
    Apr 2003
    Cleveland, Tennessee
    yes, something is shorted inside the amp
    Kelly B.
    Jan 2003
    Norcross
    sounds like your amp has a bad power supply.
    91 REX Wanna be SI
    Sounds like a a dead short to ground
