- suspension problem
suspension problem
Well, yet another problem with my accord
. Whenever im driving, i sometimes hear a popping/clunking sound from my suspension. Most of the time it happens at low speeds or whenever i go over a speed bump. Its annoying the hell out of me and i checked and nothing seems to be loose in the suspension. The Cv axles are also ok cus normally they would make a popping sound if they're busted. Any suggestions on what could be the issue?
are u using coilovers or lowering springs?
could be the stock rubber bushings in the control arms or suspension dry rotten or cracked and rubbing
might wanna check shocks or springs...but err i dunno i bent one of my shock rods...it wasn't good lol...got it replaced after i got coilovers..bump.
- Rep Power
- 22
Try TIghting the bolt on the top of the Struts mine used to do that and if its the same thing its the metal sleeve hitting, its nothing too bad just needs to be tightned up if it wont go any tighter then possibly take the bolt off and put a washer underneth it and tighten it till the metal sleeve wont move...
btw im on lowering springs(eibach sportlijnes w/Kyb Agx shocks).
- Rep Power
- 24
- You may not post replies
- You may not edit your posts
Forum Rules
