ALL BRAND NEW IN THE BOX!! PICTURES GO IN ORDER AS PRODUCTS DO.
1. C907 10 disc CD changer - will work with Kenwood headunit only.
- CD Text display (with encoded discs)
- disc naming for 100 discs
- DRIVE distortion reduction circuitry
- zero-bit mute circuit
- CD frequency response 10-20,000 Hz
- CD signal-to-noise ratio 96 dB
$135.00 Retails for $200
2. C929 10 disc CD changer - Kenwood headunit only.
-plays CD-R and CD-R/W discs
-1-bit D/A converter with 20-bit resolution
-DRIVE distortion reduction circuitry (reduces digital distortion for improved clarity)
-zero-bit mute circuit shuts down changer output when no signal is detected (as in between CD tracks)
-CD Text display (with encoded discs) on compatible receiver
-optical digital output
-disc naming for 100 discs (with compatible receiver)
-CD frequency response 5-20,000 Hz
-CD signal-to-noise ratio 96 dB
-16-1/2' connection cable included
-10-1/8"W x 3-3/16"H x 7"D
$135.00 Retails for $250
3. KFCXR50P - Real nice component set. REAL NICE!!
-4-Layer Heat-Resistant Voice Coil
-Butyl Rubber Surround
-Dual Neodymium Magnets
-Impedance: 4 ohms
-Magnet Weight: 0.21 oz
-Pearl Mica Injection-Molded Polypropylene Cone
-Pearl-Mica Injection-Molded Polypropylene Dust Cap
-TIL Voice Coil Bobbin
-Tweeter Features
-Flexible 2-Way Mounting (Surface/Flush-Angle)
-Impedance: 4 ohms
-Neodymium Magnet
-Swivel Tweeter Mount: +/- 30 degrees
-UFLC Soft Dome: 1"
-System Features
-2-Way Component Passive Crossover
-Crossover Midrange Connections: Through/Low-Cut
-Crossover Speaker Terminals: Gold-Plated, Screw-Type
-Frequency Response: 40Hz - 30kHz
-Impedance: 4 ohms
-Power Handling: 160 Watts
-See-Thru Plastic Crossover Cover
-Sensitivity: 90dB
-Tweeter Attenuation Adjustment: 0dB/ - 2dB/ - 4dB
$110.00 for a set. Cheapest I found was $189.00
4. KFC X138 - 5 1/4" 160 watt 2 way speaker.
-3/4" PPTA Film Balanced Dome Tweeter
-5-1/4" Silver PBO Advanced Fiber Cone Woofer
-High-Grade Crossover Capacitor
-Heat-Resistant Voice Coil
-Gold-Plated Speaker Connectors
-Polyamide Damper
-Aluminum Voice Coil Bobbin
-Bi-Wire Connections
-Frequency Response: 28Hz - 40kHz
-Impedance: 4 ohms
-Magnet Weight: 8.0 oz
-OFC Speaker Wire
-Rubber Surround: with Plastic Gasket
-Sensitivity: 92dB
$50.00 This is pretty much going price for them.
5.HTB-307 Kenwood Surround System. VERY NICE.
The Kenwood HTB-307 home theater in a box has all the basics you need to set up a home theater with outstanding sound. With an A/V receiver, five speakers, and one subwoofer, you can enjoy movies at home with cinema-quality sound. A digital tuner is also included, with 40 station presets, and automatic and manual tuning.
The receiver provides Dolby Digital, DTS, and Dolby Pro Logic II 5.1-channel decoding for both movies and music. Bass management, bass boost, and audio DSP listening modes give you control over the sound so you can tailor the settings to your needs. The five speakers pump out 100 watts each, and the subwoofer (with 100 watts power) gives richness and depth to music and movies.
Connect a DVD player, satellite tuner, or other components with the variety of input and options. Audio connections include two coaxial and one optical digital audio in, six stereo analog audio inputs, and a pre-out for the subwoofer. Three composite video inputs, one composite video monitor out, and one composite video record out round out the video connections.
What's in the Box
Receiver/tuner, 5 speakers, 1 subwoofer, remote control, 2 AA batteries, user's manual, and warranty information.
$200.00 for everything. Amazon sells for $256.00
