Results 1 to 1 of 1
Thread: FS: 1990 Lexus LS400 UCF10 Asking $3,700
    Default FS: 1990 Lexus LS400 UCF10 Asking $3,700
    I need a quick sell due to finances. This is my second daily and also the 2nd owner.. had plan on giving it more tlc but plans changes. Not even have time to clean the car for photos but selling as is:
    Original miles. Overall good car for the engine/transmission. Tires fairly new. Everything original and unmolested except the antenna delete and back emblem delete. Everything else is original.
    The good: water pump / timing was done at 75k. No emissions necessary for the year of the car. Couple issues: speedometer doesn’t work. Fender bruised/ indents . Good for a project car or daily driver minus the v8 gas. Lowest miles you probably ever see for an ls400 ucf10 1990.
    Cosmestics: Paint is okay, will shine with buff, but I was in the middle of a rear emblem delete and antenna hole delete to prep for a clean car, it needs slight paint- minor body work. Same with the fender- it was dented in due to a minor incident that left the fender dented in. two front door carpet pad on door pockets fell off. Carpet pads need cleaning or buy new- Interior is overall clean - except conditions stated.
    Motor and transmission is good: car drives very well and built- much better than my 2012 honda civic given the year of this lexus. minor issue with the speedometer - very common issue is that doesn't more- etc. all other needles work except RPM and speed. I might know someone to fix - or lexus forums would help you out. No known car leaks. Air compressor was swapped brand new by my license mechanic - $400 job- so ac blows ice cold. -
    Asking price $3700
    Phone number: 678 232 7032
    Attached Thumbnails Attached Thumbnails -ls1-jpg   -ls3-jpg   -ls2-jpg   -ls5-jpg   -ls-jpg
Tags for this Thread
