Results 1 to 2 of 2
Thread: FS/FT: 1995 Laser Red Mustang Stroked And Blown 355 Dart Block $15,000 OBO
    V8+Boost=Fun armyed's Avatar
    Atlanta/Baghdad
    Default FS/FT: 1995 Laser Red Mustang Stroked And Blown 355 Dart Block $15,000 OBO
    Been going back and forth about selling this thing for a few years and I think it's actually time that I'm going to do it so I can get into a newer 2011-2015 5.0 turbo car. Car has the full A/C setup (Car runs to hot for my taste during summer with A/C on) and heat. It is in need of a paint job but the Laser Red still looks pretty good. Rear passenger tire rubbed when I first went with a large rear tire and waved the fender were the tire was close a little bit. Car put down 636RWHP with the Vortech SI blower, 2.95 pulley and stock Vortech crank pulley. The motor/drive train in the car is capable of so much more, I just never tried to go crazy with the power(Bigger Blower). The car is located in Marietta Ga. I'm out of the state/country a lot of the time but could always set something up. Here's a list of most of the stuff done to the car. I'm sure im missing some stuff in the list that was just replacing old parts but most of the stuff in in there. Car has almost 158k miles on it, Engine/Drive-train has no more than about 5000 miles (If That) on it. Last time I weighed it the car was 3450lbs with 1/4 tank of gas and me not in it. Thanks [email protected]
    PRICE UPDATED
    $13K Or Trade
    Anthracite FR500 18x9 Fronts 18x10 Rears
    265/35/18 Nitto 555 Front tires (1000 Miles)
    305/35/18 ET Street II Mickey Thompson D/R's Back (1000 Miles)
    Saleen S281 Wing
    Cobra Crystal Clear Headlights
    Cobra 160 MPH White Faced Instrument Cluster
    Auto Meter Shift Light inside A/C Vent
    Suspension:
    Eibach Sportline Springs
    Strange Engineering 10 Way Adjustable Struts
    Strange Engineering 10 Way Adjustable Shocks
    Slotted and Crossed Drilled 13 Inch Cobra Front Brake Setup Brembo Rotors
    QA1 4 bolt Caster/Camber Plates
    New Polyurethane Bushings Front Sway Bar
    Edelbrock Dual Adjustable Upper Control Arms
    UPR Lower Control Arms
    Dart Iron Eagle Sportsman block 8.2 deck 355 Stroker built by Mo's Speedshop (.30 Over, long throw)
    Eagle Stroker kit
    4340 Eagle crank
    Forged JE pistons
    4340 H beam rods
    Vortech SI Supercharger with RR 2.95 pulley (1000 Miles)
    Vortech black powder coated discharge Pipe
    UPR Power Pipe
    Mr. Freeze Meth Kit(Big Nozzle)
    Comp Cams Hydraulic lifters
    Comp Cams Ultra Gold 1.6 RR's
    Billet Cam (Forced Induction Spec, honestly can't remember which one, 560ish lift)
    Trick Flow 75mm TFX Throttle Body (Fox Setup)
    60# Injectors
    80mm MAF
    ACCEL Extreme 9000 Ceramic Spark Plug Wire Set
    NGK Spark Plugs
    Smog Pump Delete Pulley
    99-04 GT Ford Clutch Cable w/UPR Adjustable Clutch Quadrant
    Black Powder Coated Holley Systemax Intake
    Ported Edelbrock Victor Jr 60cc Heads 2.05/1.60 205cc w/Cometic head gaskets
    Comp 929 Springs
    Aeromotive Stealth Fuel Pump - 340lph In Tank / T-Rex inline Secondary Pump
    Edelbrock Intake Elbow EGR Delete Plate
    Cobra Front Brake Set Slotted/Crossed Drilled Brembo Rotors
    Adjustable Fuel Pressure Regulator
    Powermaster PowerMAX Starter 9103
    Energy Suspension Poly Motor Mounts
    2 Flu Aluminum Radiator
    Chrome Overflow Tank
    Mr Freeze Meth Injection
    6AL-2 Ignition Box w/2 step (2 step not hooked up yet)
    SCT 4 bank chip tuned by Mo's Speed Shop
    Trans Back:
    TKO 600 26 Spline
    Energy Suspension Poly Transmission Mount
    Pro 5.0 Short Throw Shifter
    Spec Stage 3 Clutch Setup
    Ford Racing Aluminum Drive Shaft
    Ford Racing 3.73 Gears
    8.8 With Welded Tubes
    Moser 31 Spline Axles
    Ford Racing 31 Spline Trac Loc w/ extra clutch
    Exhaust:
    1 5/8th Mac Equal Length Headers
    2 1/2 Inch Off road H-Pipe
    40 Series Flows
    Chrome exhaust tips
    My car is my other wife. I don't spend as much time with either as I should, but when I do I drive them both crazy.
    Atlanta/Baghdad
    TTT Price updated $13k or trade
Tags for this Thread
