Results 1 to 3 of 3
Thread: Rbc intake manifold, kswap header, bolt in shift box, & lots more
    Default Rbc intake manifold, kswap header, bolt in shift box, & lots more
    Contact: 7062204204
    Pictures upon request
    Rbc intake manifold. Has injectors throttle body fuel rail: 150$
    New Hybrid racing z3 bolt in shift box: 300$
    Hybrid eg swap mounts, polished. 400$
    Kswap clutch line: 30$
    Aeromotive fpr w/guage: 75$
    Rsx 36mm oem axles: 75$
    K-swap header new: 150$
    02-04 charge harness: 50$
    K24 eagle rods: 150$
    Rsx half shaft: 75$
    Z3 starter: 50$
    Z3 alternator: 75$
    2x Ep3 idler pulley: 75$
    Rsx base trans: 300$
    Z3 water pump/housing: 75$
    Z3 flywheel 80k miles: 50$
    Z3 ac compressor: 75$
    K coil packs: 50$
    99-00 civic ex cluster 103,xxx miles: 75$
    Obd0 to obd1 conversion harness: 50$
    Gsr blades, decent tires, painted black: 200$
    KindaInformedNoob! Joppa_Smoot's Avatar
    Augusta Ga
    still have the ac compressor?
    IA Member ReXy5709's Avatar
    Jul 2009
    Has the rbc been modified and mounted or fresh and unaltered
