Results 1 to 4 of 4
Thread: What is it!?
    Unknown
    May 2014
    Dawsonville, GA
    Default What is it!?
    So I was working through my wiring under the dash of my '93 Civic EX, and I've found this spliced into the black with white stripe wire that I believe is coming off my ignition switch. The "plug" of sorts was just screwed to the bottom of the dash with the solenoid looking thing stuffed up around the steering column. Does anyone know what this is?
    -plug-jpg
    <MaximumTouge> ssonsk's Avatar
    Nov 2012
    Paulding County
    Are the wires spliced or are they rerouted through that thing?
    Leave it to E36Slide to turn a thready gay.....like everything he touches.
    I like telling everyone I know that we are extremely personal friends.
    And I still have your cell phone number from that one time we traded wheels.
    And I'll sell it to them for $5.
    Unknown
    May 2014
    Dawsonville, GA
    The black with silver stipe wire is running through it.
    Johns Creek
    It's an immobilizer. Back in the late 1990's and early 2000's a lot of people had them installed. Basically, it routes the starter wire through a relay for starter kill, but instead of using the output of a car alarm to click the relay, it uses a flat "key" that has to be inserted in order to allow the starter signal to pass through the relay.
    If you want to remove it, reconnect the black/white wire to itself on the main harness, and remove the rest of it.
