Results 1 to 2 of 2
Thread: Better Track Prepped J30
    J30BIRD haz MANUAL swimshark's Avatar
    Oct 2009
    Lilburn
    Default Better Track Prepped J30
    I have been out of this for so long hah. I have spun rod bearings in 2 of my J30 motors and after finally getting a look at the oil pan of a 300zx, I can see why. The J30 pan is made different because of steering rack location. Well I guess Nissan did not think someone would actually get one of these cars on to a track, so they did not baffle the pan around the oil pickup. So I have been sucking up air while taking turns on the track, YAY!!! (lots of sarcasm). So for m 3rd motor I bought a Tomei universal trap door baffle kit that you custom fit to your pan.
    I used to have an E30 vert that got totaled Dec 2012 and picked up an E28 535i that is my new daily, so the J30 project has been on going since August of 2012. Just working on it when I got time and money to blow on it. Mainly focusing on school now.
    So here is the MOD list of what is done to the J30. It is not running still because still getting intake worked on and waiting to buy the front suspension needed. The rest of the car is completed though and it is ready to hit the roads after a serious alignment since I added the full line of SPL Parts adjustable control arms in the front and rear.
    Motor/Drivetrain
    Motor
    -90 Z32 Block (new rod bearings)
    -94 J30 30P Heads
    -91 Z32 5 Spd Camshafts
    -Custom made oil pan with Tomei universal baffle kit (no more dry pickup for oil)
    -Z1 Adjustable Exhaust Cam Gears
    -Z1 Poly Motor Mounts
    -Selin Dual Maf Translator
    -Z1 3" Silicone Intake Hose
    -Dual N62 MAFs
    -Stanza 60mm throttle bodies
    -AMS Under Drive Pulley Kit
    -Electric fan and shroud from Ford Taurus 3.8L with custom wiring harness
    -300zxTT Radiator
    -EGR Delete
    -PRVR Delete
    -TBC Delete
    -AAC Delete
    -Balance Tube Relocation
    -Fuel Line Tuck
    -EFI Harness Tuck
    -Relocation of fuel filter, power steering reservoir and coolant overflow
    -Oil Catch can added to PCV system
    Transmission
    -Z1 NA Performance Clutch pack with 6 puck clutch
    -Fidanza Lightweight Flywheel
    -Custom Driveshaft from Drive Shaft Services (DRIVE SHAFT SERVICE: HOME)
    -Z1 Premium Short Throw Shifter
    -Z Speed Solid Shifter
    -300zx 5spd Transmission
    Suspension
    Front
    -S14 Custom Valved Coilover Cartridges from BCRacing
    -Mitsubishi EVO VIII Tein Camber Plates
    -S14 5 lug w/ABS front spindles
    -S14 Tie Rod and LCA Ball Joints
    -SPL Suspension 300zx Front Tension Rods
    -12k Springs
    -300zx Front Sway Bar
    -S13 Sway Bar Endlinks
    -Energy Suspension Poly steering rack bushings
    Rear
    -S14 Apexi Rear Coilovers
    -Z1 300zx Rear Subframe Bushings (Red)
    -SPL Suspension 300zx Adjustable Rear Upper Arms
    -SPL Suspension 300zx Adjustable Rear Toe Rods
    -Energy Suspension Poly Diff Bushings for 300zx (Red in Subframe)
    -S13 Solid Front Diff Bushings
    -10k Springs
    -300zxTT Rear Sway Bar
    Brakes
    -Z1 13" BBK (Cobra Cross Drilled and Slotted Rotors)
    -300zxTT Calipers on all 4 wheels
    -Cross Drilled and Slotted Rear Rotors
    -300zx SS Brake Lines
    -Motul 600
    -Z32 TT BMC
    -Carbotech pads
    Interior/Lighting/Sound
    -Pulled all interior and cleaned it, even re-dyed the whole interior
    -Custom interior harness to control lighting and fans
    -Custom Angel Eyes Setup on headlights
    -55W 6k HID low beams
    -35W 3k HID fog lights
    -ProCarParts Glow Gauges
    -Panasonic CQ-VD7003U 7" pop out touch screen HU
    -JL Audio 500/1v2 AMP
    -Kicker CompVR12
    -JL Audio 300/4v2 AMP
    -Alpine SPR-60C 6-3/4" speaker with 1" component tweeter
    -MBQuart RWE169 6x9 with crossover
    -Battery relocation to the trunk with a Yellowtop Optima Battery
    -Black Nissan 350z Cloth Seats mounted to J30 seat rails (electronics work haha)
    And now for a plethora of pics
    Senior Member psychodrama_81's Avatar
    Looking good, hope to see the J on the road again one day!
Tags for this Thread
