Results 1 to 4 of 4
Thread: 1998 Ford Mustang Cobra Convertible Show/Race car $16,500
    IA Member 67MercCougar's Avatar
    Suwanee
    Default 1998 Ford Mustang Cobra Convertible Show/Race car $16,500
    Its a real black on black on black Cobra convertible and have documentation and proof from MV performance that the car is everything listed.
    I may be leaving some things out but this is all I can think of at the moment. The original car has 130,xxx miles but as you can see nothing is stock really anymore. When the motor was built a new starter, alternator, belt tensioner, coolant sensors, mass air, knock sensor, cam sensors, water hoses, one new a/c line as it had a small leak were all replaced as well.This is a low compression motor as it was supposed to be a turbo car. $9,500 OBO or trades for a truck of lesser value. Thanks for looking text me please as it is easier
    678-665-1675
    Motor around 20,xxx miles
    .30 over aluminum Teksid block
    Ported 03 Cobra heads
    Ported 01 Cobra intake
    Mahle forged rods
    Probe industrys forged positions
    Eagle forged 8 bolt crank
    Full k&n intake
    SCT tune
    SCT 3 bank chip
    Egr delete
    Dpfe delete
    Cat delete
    Secondary air pump delete
    Ford racing high volume oil pump
    B&M stainless oil cooler
    Oil filter relocation kit
    Optima red top battery
    Hardened race bearings and rings
    Mac long tube headers
    Bassani x-pipe
    Flowmaster 40 series cat back
    Carbon fiber oil catch can
    Transmission around 50,xxx miles
    Mach 1 transmission from a 03 Mach1 T3650
    Steeda Tri-ax short throw shifter
    Spec stage 2 clutch about 20,xxx miles
    Fully adjustable quadrant and firewall adjuster
    Ford racing aluminum drive shaft
    Rear end
    8.8 rear axle
    373 gears around 40,xxx miles
    Moser 31 spline axles
    Interior
    Mach 1 front seats
    Modified to fit Mach 1 rear seat
    Mach 1 silver a/c panel
    Mach 1 silver shift panel with billet aluminium trim
    Billet aluminum a/c knobs, headlight switch, defrost switch
    Ford racing aluminum pedals
    Mach 1 center console
    2 gauge pod around gauge cluster
    Electical
    Boston Accustics component front speakers
    Boston Accustics component rear speakers
    Stewart Warner Oil pressure gauge
    Stewart Warner Fuel air mixture gauge
    Alpine 550 watt amp for interior speakers
    Sequential turn signals
    Kenwood head unit with iPod cable running to glove box
    8000k HIDs
    Suspension
    Lowering springs from PO not sure brand
    Motor craft front and rear struts
    BBK camber/caster plates
    Poly urethane sway bar bushings
    03 Cobra front sway bar
    QA1 tubular k-member
    Mac sub frame connectors
    Exterior
    Full custom paint job with body line stripe that's painted and flush with the rest of the paint
    Saleen 281 carbon fiber hood
    Saleen 281 spoiler hydro dipped carbon fiber
    Black 2 piece headlights
    Custom painted coil covers to match paint job
    Powder coated intake, coil brackets, timing covers, mass air flow body
    10th anniversary Cobra wheels 9" front on a 245/45/17 10" rears on a 275/35/17
    Cross drilled vented slotted and zinc coated front and rear rotors
    04 Cobra convertible top from a garage kept Cobra that got T-boned had 32,xxx miles much nicer top being cloth over the factory vinal
    1967 Mercury Cougar, bored out 289.
    1998 Ford Mustang Cobra convertible. Fully forged DOHC 4.6.
    BUILT NOT BOUGHT!!!!!!
    Jul 2010
    c,ville
    nice!
    Suwanee
    Price reduced because of a cracked hood $10,800 OBO OR trade for a truck of lesser value plus cash
    Suwanee
    Still for sale, price has dropped to $9,500 OBO. Thanks
