Up for sale I have some parts I had laying around from my build.............. Darton Sleeved Sleeves 84.5mm block $600.00 ( block is leaking slightly through one cylinder at the bottom where the sleeve meets the block (See Pic) fixable. ALL THE SLEEVES ARE PERFECT NONE ARE CRACK!! Not a lot of pressure just dripping if u want I can pressurized the block so u can see for your self). Cp Pistons 84mm 9.5:1 Compression $400.00, Eagle GSR Rods $250.00 both together $550.00. t1 Race Development Bosch pump and fittings with braided line to run inline pump and in tank pump $400.00. Omni 3 Bar Map sensor $80.00. Huge intercooler should be good for about 600 hp $150.00 HKS BOV $80.00 2.5" turbo piping came from a civic$ 100.00 (turbo kit together $300.00). AEM blue spark plug cover Anodized $ 80.00. B Series Oil pan for Turbo $80.00. GSR Valve cover $70.00... ARP GSR head studs One Missing $80.00. Stock OEM Gas Tank Can from 2000 Honda Civic EX $150.00. 3" Turbo V band Flange and Clamp $ 50.00. Brand New WALBRO 255LB PUMP $80.00 AEM FUEL FILTER HONDA MICRON REPLACEBLE $90.00. Brand new Cometic 85mm GSR Head Gasket $80.00. Brand new Cometic 84mm LS VTEC Head Gasket $80.00. Brand new 85mm Golden Eagle Head Gasket $100.00. GSR OEM CAMSHAFTS $90.00... OEM CAM GEARS B SERIES $30.00.
PRICES ARE OBO CALL OR TEXT
678 860 9924 or 264 476 6644
