Results 1 to 10 of 10
Thread: 92-95 civic EG A/C system Compressor, Condensor, fan, lines,all bolts $150 (Atlanta)
    Wanting Boost! rsxappeal's Avatar
    Default 92-95 civic EG A/C system Compressor, Condensor, fan, lines,all bolts $150 (Atlanta)
    From a 95 civic I pulled the whole A/C system out when I put a new motor in it. Everything works perfectly. I have the compressor, and the bracket that the compressor bolts to the block. I have all the bolts for everything as well. Also comes with the Condensor with fan attached. Also comes with the lines that connect to the compressor, etc. Even comes witht the brackets that bolt the condensor to the radiator stay. This literally is everythng to get your A/C working if you don't have anything but the main line in your engine bay.
    Call/Text Brian at 770-468-2937
    TTT!
    BUMP
    TTT, can part out if needed. I know someone was interested in the compressor and someone else was interested in the upper line.
    Got stacks on deck nismo4's Avatar
    Houstontlantavegas
    hey man where are you located? i would like to scoop up a few parts
    I do OBD1 Emissions blue94eg6's Avatar
    Dec 2008
    Still have the compressor if so how much?
    TTT. Still have everything
    Your mom's bed
    How much for the compressor? Where are u located?
    $75 for the compressor. Located in Atlanta, can meet locally.
    TTT. Man it's hot outside. A/C is a must!
