Results 1 to 10 of 10
Thread: 00 SI B20v stumbles
    IFUKSWITYA
    Spankys Speed Fab
    Default 00 SI B20v stumbles
    I have a 00 SI obd2 b20 with gsr head and aftermarket intake.L
    Car ran perfect when i removed the b16 it was just tired.
    all sensors are hooked up and working except for o2 sensors. (ckf sensor, knock, evap on fuel rail all working)L
    used the snap on scan tool and tps sensor is adjusted correctly, map reads correct, no misfires)
    this engine has 50 miles on it since i assembled it. timmlng is dead on. plugs and wires are new.L
    problem: car doesnt idle on its on unless there is tension on the throttle cable. when driving, anything over quarter throttle and the car actually slows down. begins to hesitate, miss, pop, and backfire.L
    help please!!!!
    I have done so much,
    with so little,
    for so long,
    that i can make anything,
    out of nothing!!!
    Certified Gearhead Manny Naber's Avatar
    Nov 2012
    do you have a wideband? Could be a possible fuel injector issue
    1994 Nissan Skyline BNR32- Currently being built for 1000+awhp (the works)
    2003 Subaru Wrx (jdm sti ext.conv)- 6.0 LSx , T56, Fast 92 TB,IM,MS4 cam,+++
    1995 Nissan S14.5- Sr20det, built motor, full race 3071r turbo kit, z32 tranny+++
    1997 Honda Civic Ek Hatch- In process: K24/20 BC stroker, custom turbo kit, tubbed +++
    IS IT TUNED??
    Wait, I bet it's running the b16 ecu still huh?
    IFUKSWITYA
    Spankys Speed Fab
    Injectors came out of previous running engine and were clean
    yes it is still on the stock ecu due to obd requirements
    with so little,
    for so long,
    out of nothing!!!
    barrow county
    i smell lean.
    i had same problem when i did lsvtec with gsr head. it rain peferct when it was a gsr and ran like poop after conversion with stock gsr ecu
    Quote Originally Posted by Superslow95 View Post
    Get with the program bro, stock 1.6 ecu is not gonna run a 2.0 correctly!!
    IFUKSWITYA
    Spankys Speed Fab
    It may not run it at the max power level but is should atleast idle and accelerate at low throttle. im not out flooring it.
    with so little,
    for so long,
    out of nothing!!!
    Shit be lean as fuck, yes it will run, but it's not gonna last.. I seen it time and time again, stop listening to retards bro!!
    barrow county
    when i had my old set up with the lsvtec. it'll stop wanting to pull after 4k rpm = wayy to lean. atleast get a base map chipped on. Only run about 75 bucks for base map chip
    IFUKSWITYA
    Spankys Speed Fab
    Tps checked good. o2 sensors are brand new and read right. fuel system is operating correctly
    Car has since been tuned and still has the exact problem same
    with so little,
    for so long,
    out of nothing!!!
