Thread: Em1 no start no priming check engine light stays on no spark
    Jan 2013
    Default Em1 no start no priming check engine light stays on no spark
    I have a em1 a upper radiator hose blew I replaced and tried to start and wouldn't start? I towed home and swapped a jdm gsr sense I thought the motor was F***** and same thing. I thought the dizzy was bad so I cut and spliced the plug from my obd2 to the obd1 dizzy and it turned on it ran, I cut off and tried to start again nothing no spark. I checked the ecu main relay injectors gets power everything I checked has power and ground but nothing? Been stuck for about a month can't figure it out. Please help I've looked at forums for weeks can't figure it out. All my fuses are good idk what else to do.
    Jan 2013
    Btw I'm running jdm gsr ecu, jumper harness obd1 dizzy everything else I got off from my b16.
    Jan 2013
    Nobody? I really need my car
    Apr 2012
    McDonough
    Check your neutral safety switch?
    Jan 2013
    which is that theone under the clutch? ill check it out worth a try. i just dont understand how when i installed the extra obd1 dizzy i had it had spark it started then i turned it off tried to start again and nothing? im almost ready to just pay the honda dealer price as much as i dont want to.
    Jan 2013
    anyone else have a idea or input?
    Do you own a test light or power probe, they are pretty helpful..
    Jan 2013
    yes i just looked up how to test the dizzy Part 7 -Honda Igniter, Ignition Coil Test (1.5L, 1.6L, 2.2L, 2.3L)
    doing this asap! i have a multimeter to test for continuity also. i mean im pretty good with mechanics (not as good as i think sense im stuck lol) but
    maybe im just over looking something or testing something wrong?
    Quote Originally Posted by Ek guy View Post
    Right.. It's pretty simple!! There is a fuse under dash, but check dizzy for power, coil for power, normally those can show good, but if TDC sensor bad the coil will not fire.. SO, use test light to see if coil fires!!
