Results 1 to 4 of 4
Thread: 2003 civic over heating.
    Default 2003 civic over heating.
    need help my civic is over heating at times , when i drive long trips. i have all ready replaced the water pump and put a new fan switch in it.( note: i am not loseing any coolant) i need help to fine out what else could cause this oveer heating problem.
    Projects
    Air in the system needs to be purged properly also make sure the fans are even turning on
    Best to heat cycle car in driveway with cap off to confirm the thermostat opens, no air in system, fans works, and water pump circulates...
    I heat cycle cars 2x before re-installing cap, and then test driving, that's just my
    i bleed the coolant system twice. but thanks
