Thread: Turbo rebuild recommendations
    Alpharetta
    Default Turbo rebuild recommendations
    I have a 2004 WRX STI with out 123,000 miles on it that I purchased about two months ago. The only mod to the vehicle is a HKS High Power catback exhaust. The car is smoking at idle when it warms up. I had originally thought to replace the PCV valve but that has proven to be more difficult than I had originally thought. While pulling the intercooler I noticed oil both in the intercooler and the turbo. This leads me to believe that the seals in the turbo may have gone bad. I am looking for any advice on my issue as well as recommendations for someone to rebuild the turbo.
    I also just had the valve cover gaskets and oil cooler seal replaced.
    I can rebuild it, however sometimes it's cheaper to pick up another Sti turbo
    Certified Gearhead Sil'vr-Boi6's Avatar
    Under the bridge
    I don't have wrx, but I experienced similar scenerio like you're experiencing. Are you getting smoke underneath the hood or exhaust outback? When my turbo began showing signs of failure; it smoked from my exhaust out back. I would think smoke underneath the hood could be worn gaskets from the turbo or something else. I would rebuild the CHRA before it completely become useless from a local shop. GL
    wherever
    I'd highly recommend Turbo Diesel & Electric in Forest Park- Turbo Diesel I've dealt with them a number of times and have been really happy. IIRC it was "JB" there who I talked to.
    02' Miata
    Alpharetta
    Quote Originally Posted by Sil'vr-Boi6 View Post
    The smoke was coming from the exhaust.
    Alpharetta
    Thanks for the info. They are being recommended by a lot of people on other foums.
    wherever
    No problem. By the way, it's JD..not JB. oops.
    02' Miata
    Under the bridge
    Does Turbo Diesel & Electic machine compressor housing and hotside housings?
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    yes
