Results 1 to 11 of 11
Thread: 1992 Lexus SC300
    The Gradies... KillTheCrow's Avatar
    Default 1992 Lexus SC300
    1992 Lexus SC300
    Motor- 2JZ-GE
    Miles -202XXX
    Transmission- Automatic
    Vin:JT8JZ31C6N0002720
    Clean and clear title in hand.
    Up for sale is my SC300. It’s a very comfortable and reliable ride, but it’s not cost effect for me to daily it back and forth from Atlanta on a daily basis. Only issues it gave me were overheating related and literally everything was replaced. Since it was repaired, it hasn't even tried to run warm. I wouldn't hesitate to drive this car anywhere. The AC and heat work great and it has power everything. It has some small bumps and scratches, but overall pretty good paint for a 21 year old car.
    Recent maintenance and new parts:
    -ECU
    -Head
    -Head Gasket
    -Gaskets from the head gasket up
    -Intake Filter
    -MAF
    -Timing Belt
    -Spark Plugs
    -Spark Plug Wires
    -Distributor Cap
    -Igniter Rotor
    -Radiator
    -Radiator Hoses
    -Thermostat
    -Serpentine Belt
    -Custom mounted LED voltage gauge
    -Fuel injector cleaner was run through the system
    -Oil Changed every 3k
    -Car was seafoamed.
    -EGR system removed
    -New Kicker 4" speakers all around
    -Kenwood Headunit
    -Kenwood 12" Subwoofer and amp
    Maintenance performed and parts added by previous owner:
    -New Fuel Tank
    -New Fuel Filter
    -New Fuel Pump
    -Replaced the Catalytic Converter
    -Timing Belt
    -Water Pump
    -Transmission flush
    -New front brakes
    -AC system was recharged
    -6k HID low beams, regular high beams
    -Origin Style Rear Roof Spoiler
    -Tokico Blue Shocks/Struts
    -R-SR Springs
    -Ford Mustang 94-04 Rims(16x7.5)
    -12v Fuel Mod
    I'm sure there's more that I'm forgetting, but that's pretty much the gist of it.
    Cons:
    -Driver side door panel refuses to stay completely on the door.(Working on that)
    -Passenger seat lumbar adjustment motor doesn’t work.
    -Cracked windshield. (Quoted $220 to replace)
    -Gauge cluster needles don’t illuminate, except for fuel. Fuel needle illuminates perfectly.
    -Climate control LCD is burned out along with the bulbs. Still functions perfectly, you just can’t see anything at night.
    -Hood and trunk shocks are shot; I just used a pair of locking pliers or a 2x4. It didn’t bother me.
    -Exhaust leak from cat to pipe flange. Blows out the gasket shortly after replacing. I think there's a donut gasket that is supposed to go in there as well, but I haven't had anything to compare it to.
    -Small power steering leak.
    Extras:
    There are some spare parts that will be coming along with the car such as;
    -Driver side window regulator
    -SC400 rear spoiler(Started prepping the spoiler for paint, so it’s partially stripped)
    -Automatic Shifter Cover
    -Whatever else I can find laying around.
    I'd like to get around $4800 OBO for it.
    Trades will be considered, but cash is king.
    I work EMS, so I have a ridiculous schedule, PM'ing me or texting me will be the best way to get a response. If you call and I don't answer; leave a message I will call back.
    678-548-6346
    -Korey
    Canton
    I can vouch for seller and car!
    Try not. Do or Do not.
    Thanks dude!
    Canton
    Up
    Bump.
    Bump.
    Canton
    Great deal!
    Buuuuump.
    I want this car so bad X:
    Bump
    Canton
    Bump!
