Results 1 to 5 of 5
Thread: help with tire number game !!!!
    Oct 2009
    albany ga
    Default help with tire number game !!!!
    ok i have a 2008 z06 with 345/30/19 invos mounted on the stock wheels. i just got a killer deal on a ser of rear 18 inch wheels from a c5 z06 and im wanting to find a radial to mount as track tires. they have a set of 315/30/18 radials mounted now and everything clears fine. i am wanting to fit a taller tire that is closer to the height i am running now to give me more sidewall. i know everyone runs the front 17 inch wheel but these were dirt cheap and have to do better with a radial than the invos im running now.... and help here will b greatly appreciated.
    Stock 345/30/19
    Diameter 27.1
    Circumference 85.3
    Section Width 13.58
    Sidewall Height 4.07
    MT Et street P345/35R18 28X13.50R18
    Diameter 27.5
    Circumference 86
    Section Width 13.9
    Sidewall Height 4.75
    Oct 2009
    albany ga
    that looks about as close as im guna b able to get. thanks for the help man.
    wherever
    This should help you find a tire with similar tire diameter quickly....from there, go see who makes tires in that size and find the manufacturer listed diameter. I say this because a 315/30-18 tire from two different tire manufacturers will have different diameters.
    Tire Size Calculator - Tire & Wheel Plus Sizing
    02' Miata
    Im running 18's and et streets on mine. Hooks fairly well
