Results 1 to 40 of 71
Thread: 225/40/18 Toyo Proxes
    Wink 225/40/18 Toyo Proxes
    To get the best from your car and to enjoy your driving to the full you need a tyre designed and manufactured to exacting standards - namely the Toyo Proxes T1-S. With its silica-enriched rubber compound, the Proxes T1-S gives outstanding roadholding and control in the dry or the wet. This tyre also has low noise levels, gives good ride comfort and is long lasting as well as looking aggressively stylish on all cars.
    - "Generation S" Toyo's New, Silica-Reinforced, High-Grip Tread Compound: A new smart tread compound with silica-reinforcement increases the friction coefficient between the contact patch and the road surface.
    - Silica-reinforced smart tread compound combined with an all-new unidirectional tread design with slanted main grooves for superior water drainage results in excellent wet and dry grip and resistance to aquaplaning.
    - Hard bead filler compound: The Proxes T1-S features a special hard rubber compound in the lower sidewall that provides stability during hard cornering for improved steering response and excellent grip.
    - Two full-width steel belts stabilize the tread to reduce squirm and enhance handling during hard cornering.
    - The unique tread design incorporates a rigid center rib for directional stability.
    - High Modulus Casing: Toyo uses rayon for the Proxes T1-S because of its excellent thermal stability. The performance characteristics of rayon are flat over a wide range of temperatures. This means the casing is minimally affected by extreme heat or cold assuring that steering response and high-speed stability are optimized. (A strong polyester casing is used in selected sizes).
    Spiral Wound, Jointless Edge and Cap Plies: A continuous length of nylon cord tape wound around the circumference of the tire over the steel belts creates two full cap plies or one full cap ply (depending on tire size) This assures improved uniformity for comfort and high-speed endurance.
    - CASPAN™ Noise Analysis Technology helps Toyo optimize the T1-S tread design to reduce pattern noise.
    The bead wire package is designed to eliminate joints and splices to provide precise uniformity for a smooth, comfortable ride. The configuration of the wire assures strength for stable performance at high speeds.
    - Rim Protector in the lower sidewall, guards expensive wheels from scratches and abrasions
    225/40/18 Z rated.
    4 tires slightly used, TONS of thread. $500
    Attached Thumbnails Attached Thumbnails -picture-308-jpg   -picture-310-jpg   -picture-302-jpg
    afternoon bump
    A day late, a buck short Buford®'s Avatar
    Apr 2003
    Starin' at the world through my rear-view.
    down
    My 2001 Acura 3.2CL Type-S
    Val for president!
    Yes, I would have voted for her.
    In loving memory of Valerie Antranikian.
    Quote Originally Posted by Buford
    down
    Thanks
    Morning bump
    Trades accepted!
    BUMP BUMP BUMP`
    buy me!
    No free bumps?
    DOWN
    Senior Member JASONBALL's Avatar
    columbus GA
    bump for great tires. what are you needing for trade
    I am looking for just about anything that catches my eyes, does not have to be car related whatsoever....
    Bump baby
    Bump, make offers.
    Certified Gearhead CRXchic19's Avatar
    Gwinnett.....Clearwater FL
    free bump
    Quote Originally Posted by CRXchic19
    free bump
    Thank you, you are a very fine lady.
    UP
    make offers
    bUMP
    Lawrenceville, GA
    call me at 678-437-3129
    alex.
    Sure thing my man,
    i will give you 80 bucks for the 4 of them
    Quote Originally Posted by matts13
    BUMP.
    Lawrenceville, GA
    lol.. =/
    Quote Originally Posted by XxLaZyAleXxX
    lol.. =/
    I know
