Thread: JL Audio 250x1 amp
    Auburn, GA
    Default JL Audio 250x1 amp --Sale Pending--
    Rated Power:400 w @ 1.5 ohm-4 ohm (11V-14.5V)
    THD at Rated Power:<0.05% @ 4 ohm S/N Ratio*:>95dB below rated power
    Frequency Response:5 Hz - 500 Hz (+0, -1dB)
    Damping Factor:>500 @ 4 ohm/50 Hz
    Input Range:switchable from 200mV-2V RMS to 800mV-8V RMS
    Dimensions:10.25"L x 9.25"W x 2.36"H
    Features: Differential-Balanced Input Topology: (1 pair of inputs)
    On-board Crossover:fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
    Preamp Output:2-channel (full-range, LP or HP)
    Bass EQ:variable boost up to 15dB Infrasonic
    Filter:defeatable 24dB/octave at 30 Hz Signal-Sensing Turn-On: permits operation without remote lead Dual mono speaker output
    Connections:accepts up to 8ga. wire +12V and Ground
    Connections: accepts up to 4ga. Wire
    I bought the amp brand new and used it for 3 months. No scratches. I do not have the original box unfortunately.
    $250
    Attached Thumbnails Attached Thumbnails -26_1_b-jpg   -aa_1_b-jpg
    trythefly
