I am selling most of what you need to add AC to your car.
These (except for the Integra fan) came out of my Hatch. It should be a perfect bolt-in affair for all 94-01 Integras and 92-95 Civics. I am fairly certain it's a bolt-on for 96-00 Civics, either way, look it up first to make sure. The only things you'd need besides what I am selling are condenser and AC lines (and I would pick up a dryer and expansion valve too, since they're cheap and it's recommended to get them new when you redo your AC). I can include my old expansion valves (I have two) and dryer, if you wish.
What you're getting:
Everything worked before I pulled it a few months ago, but again I recommend new expansion valve and dryer before you put it on your car. I plugged the compressor holes as soon as the lines were removed, so it's uncontaminated and sealed. I did not drain it, so it's ready to be emptied and to receive new oil.
List of parts you're getting (some of the stuff not pictured):
- Evaporator assembly with two expansion valves (in case you want to try cleaning one, but they're cheap new anyways)
- TWO Condenser fans (one from the Civic, might need new motor, the spare one from an Integra - works perfectly)
- Original OEM AC Compressor (old oil inside, I will provide you with fresh PAG46 oil that cost me $15)
$120, all sales final, parts sold "as-is".
If interested, text: 786-2oo-ThreeThreeTwoOne or PM me.
Thanks.
