94-01 Integra GSR front calipers with Metallic performance pads - 55$
This is a pair of calipers from a 1998 Integra GSR, they are in great shape, no problems. The pads with them are RMSA, and are FF rated, they are a street/track pad that are great on the track, brand new.
BOLT ON upgrade for any 88-00 Civic EX (has to be an EX model because of the knuckles) and bolts onto any 90-93 Integra as an upgrade as well.
DX/S2000 brake upgrade - $375
This is a for a front brake setup for all 88-00 Civics with the stock 9.5" brakes. Our steering knuckles have the tabs pulled in and don't work with a lot of other setups. However, now there is a great, lightweight option without even needing to change steering knuckles! This setup comes with S2000 calipers, modified brackets, pads, new rotors, and centering rings. It is a bolt on for all 88-00 Civics and all CRXs that have the 9.5" brakes, such as all DX, CX and LX models, CRX HF and Si, 92-93 Civic Si without ABS, and any 88-00 Civic or 90-01 Integra with Civic DX steering knuckles.
This setup uses the lightweight S2000 calipers and 11" rotors and clears 15" wheels (and some 14s such as the RacingHart CPF, Volk TE-37 and TE28, Kosei K1s, and others but I don't know which.)
94-01 Integra GSR rear swaybar - $35 local only - Atlanta area
Here is a rear swaybar with pictured endlinks and D-brackets from a 1995 Integra GSR. Bushings are in great shape. Local pickup, or willing to meet around north Atlanta area, maybe farther if you buy me a frappuccino.
4x100 Integra Type-R front brakes upgrade for Civic EXs and Integras - $310
This is a set of the rare 4x100 front brakes for a Civic and Integra. This is a pair of ITR front calipers with the 23T brackets machined to fit the 4-lug knuckles. This also comes with a new pair of Prelude VTEC rotors. This was made by a former member of h-t.
This brake upgrade is a behemoth of an upgrade over stock, using the big ass Type-R calipers with the 57mm pistons. The brackets were precision milled to fit. The rotors were redrilled with a milling machine to 4x100. This bolts onto any 90-01 Integra (exc 96 ITRs), and any 88-05 Civic EX, 99-00 Civic Si. This can fit any other 88-00 Civic if you get Integra or Civic EX knuckles, as their knuckles are different with regard to the caliper mounting point.
You will want either a 15/16" or 1" master cylinder if you have a Civic.
I have a pair of drilled/slotted rotors too, just ask.
EK 96-98 Civic headlamps with broken tabs - 35$
These are OEM Honda headlamps (made by Stanley) for a 96-98 Civic. They are in good working condition, but one has a broken tab, the other has two broken tabs. Maybe someone wants em because they have clear lenses and were never disassembled. Bought from a dealership new in 2004 and kept waxed, so they aren’t yellowed, and the car was garaged.
EK 96-98 Civic Sedan Domani taillamps - 20$
These are the rear taillamps for 96-98 Civic Sedans only. They are red/white opposed to the red/orange found stock. These are similar to the Acura 1.6 EL taillamps.
Integra GSR 97 DC springs and shocks - 80$
These are the 4 springs/shocks from a 97 Integra GSR. Great upgrade for any base Integra, or EG/EK Civic. The springs are in exceptional shape. The shocks aren't blown, there in great shape, but the rear ones may need work. The bolt on the top is loose on the left one, and the shock fork bolt was seized, so the nut was dremeled off. This is still in very usable shape, but you will need either a nylon flange nut or a nut with a lock washer.
96-00 Civic EK shocks and springs from 99 Civic EX coupe - 15$
These are the rear OEM coilovers from a 99 Civic EJ8. Will fit all 96-00 Civics, shocks are not blown, tophat bushings are in great shape, can bolt right on.
[img] http://imageshack.us/a/img14/5427/ej8rearshocks.jpg [/img]
CL brake upgrade for 9.5" Civic Brakes - $395
This is a brake upgrade for Hondas with 9.5" brakes such as 88-00 Civic DX and LX models, CRXs, 1st Gen Integras and 1st gen CRXs.
This is a 11" brake upgrade for DX Civic knuckles. This setup uses Acura CL calipers, precision modification to the brackets to fit, 11" new rotors and hub-centric centering rings made from T6061 aluminum. This is THE best brake setup to clear a 15" diameter wheel. This uses a stronger caliper than the Type-R with a slightly larger pad. The setup comes with calipers, brackets, set of pads, new 11" discs and the centering rings. Its a bolt on to Honda/Acuras with the 9.5" stock brakes (or DA/DC Integras and EX civics with a DX civic knuckle swap.)
This has a big piston, so a 15/16" MC at least is recommended.
D-series plug wireset – OEM – 6$
Wireset for a D-series. Will work on 96-00 Civics, and most 88-95 Civics that have the spark plugs in front of the valve cover, won’t fit 12 valve D15s. Resistance is around 11k for all 4 of em, which is excellent, they got about 80k miles on em.
D-Series alternator - 15$
This is a starter from a 2000 Civic DX coupe. In excellent working shape.
D-Series non-VTEC distributor - OBD2B - 25$
This is a distrubutor from a 2000 Civic DX D16Y7. This can work on other D-series, but not VTEC heads. Its in good shape, comes with the factory Sumitomo numbered wires and the cap/rotor. Cap and rotor are in good working shape.
D16Z6 complete intake manifold/throttle body - 30$
This is an intake manifold from a 1995 Civic EX. Comes loaded with the fuel rail, injectors, stay bracket, throttle body with FITV, MAP and TPS sensors and FPR. TB gasket is in decent shape, you won't need a new one.
96-00 Civic DX/LX/CX/HX Master cylinder ( MC ) - 10$
This is a 13/16" Brake master cylinder from a 2000 Civic DX. Fits all 96-00 Civics (and 98-01 Integras.) In good working shape.
Integra GSR 15s" "Fat Fives" - 225$
This is a set of GSR Fat 5s with decent tires. Two of the tires have about half the life left, two have closer to 25% of the life left. The wheels look like they were painted silver, only one has the center cap. They aren't bent, perfectly round, no damage to the lug holes and are in excellent working order. These would be a great candidate to restore, polish, paint or whatever you'd like. They are 4x100, 15"x6, Can fit type-R and NSX brakes under these bad boys. You know em, you love em.
Located north of ATL, but I'm willing to ship. All forms of payment welcome, paypal adds 3%.
