Results 1 to 5 of 5
Thread: Sir Pistons
    Default Sir Pistons
    I'm trying to find civic Si-R pistons for a B20 engine block(84mm). If you have it please let me know.
    Dec 2011
    Pensacola, FL
    No oem civic motor ever came with 84mm pistons. For that you'd have to look at aftermarket, CP/Wiseco/JE.
    thanks. I though the B20 pistons were 84mm.
    B20B/B20Z
    1999 - 2001 specs
    NON-VTEC Found in: USDM CRV as a B20Z, CR-V and Honda Orthia as a B20B Displacement: 1,973 cc (120.4 cu in)
    Power: 143 hp (107 kW) @ 6200 rpm
    Torque: 133 lb·ft (180 N·m) @ 5600 rpm
    Rod length: 137 mm (5.4 in)
    Compression: 9.6:1
    Bore: 84 mm (3.3 in)
    Stroke: 89 mm (3.5 in)
    Redline: 6,800 rpm
    This is what I found, can you tell me if this information is wrong?
    ls2
    Anniston,Al.
    He said no oem CIVIC motor came with that bore. That is a CRV motor.
    2006 gto 6 spd intake/wr 12.8@108
    2003 Chevrolet Tahoe Lt stock dd for the wifey
    1994 Honda civic EX Sdn stock dd for me
