Thread: Wtf is this and can it be removed?
    Honda spinks's Avatar
    Jul 2009
    Woodstock
    Default Wtf is this and can it be removed?
    1991 Honda Prelude 2.0 SI
    B20A5
    Motor blew and I'm taking out everything that isn't necessary and putting a new motor in. Was wanting to know what exactly this is and if it can be removed.
    Certified Gearhead Manny Naber's Avatar
    Nov 2012
    flux cap
    1994 Nissan Skyline BNR32- Currently being built for 1000+awhp (the works)
    2003 Subaru Wrx (jdm sti ext.conv)- 6.0 LSx , T56, Fast 92 TB,IM,MS4 cam,+++
    1995 Nissan S14.5- Sr20det, built motor, full race 3071r turbo kit, z32 tranny+++
    1997 Honda Civic Ek Hatch- In process: K24/20 BC stroker, custom turbo kit, tubbed +++
    Some guy. CSquared's Avatar
    Barack obama blew your motor.
    Nov 2012
    But seriously I don't know, can you take a few more pics at diff angles?
    It most likely looks like some sort of old EVAP setup.
    LAWRENCEVILLE
    looks like the map sensor and egr purge valves you need both for it to run right.
    Hella stock member!
    Nov 2012
    egr purge valve should have a hard line too it. Is there a vacuum line to it? Could be a old vacuum saver block type thing, but looks like evap if that's liquid in there
    Jul 2009
    Woodstock
    I think that its both evap and map. Thanks for the help guys.
    CLEANEST ironDUKE
    Dec 2009
    Gainesville, GA
    ok nOObs, yes you can delete the black box. how ever you will need to lengthen the map sensor wires so you can hide it under the intake. as far as the other stuff controls the egr, if you want to get rid of it you can. but you will eventually throw a code. unless you get a chipped ecu to delete the egr. your in a 91 so your already obd1.
