Thread: Need some help with water leakage,,,,
    Certified Gearhead johnny_d's Avatar
    Sep 2008
    southside
    Default Need some help with water leakage,,,,
    I have my DB ( 4door 94-01 integra) and it leaking in the trunk ,,, I changed the trunk molding thing and It still leaks,,,, I adjusted the trunk and no change,,, I had to drill holes in the trunk to stop water from building up and going towards the front of the car,,,,,,,,,,, is there any silicon or special spray that I can put on the molding so it can maybe help stop the leaking, any advice or suggestions please ,,,,,
    Some guy. CSquared's Avatar
    Barack Obama. That dude cant even keep water out of your trunk.
    Sep 2008
    southside
    my prelude does the same crap, pisses me off, i had to also drill holes at the bottom of the spare tire compartment to keep water from building up, the only thing i can think of it either the tail lights seal, or the drain tubes that come from the sides of the sunroof under the headliner
    Sep 2008
    southside
    i dont have sunroof and i changed the taillights gaskets already(brand new) i put the water hose on top of car and dropped the back seats to see and it leaking from the sides but i changed the seal and the aligned the trunk and still no difference
    It's all about JDM.
    CA to GA
    so when you sat in the back seat and trunk, and used a hose to pour water down the trunk, where was it leaking exactly? did the quarter panels or rear have an accident before? maybe the previous owner, replaced a quarter panel, and didnt align correctly. Try that water hose technique and see what exactly is happening. Then make sure the trunk gasket/weather stripping is sitting properly.
    Quote Originally Posted by gsrteg View Post
    Let's get more water in the car.. Ummm no! LOL
    Smoke method works best!!
    Sep 2008
    southside
    Never heard of the smoke method,,,but as for the water method I did it again it coming from the corners were it starts to curve (near the trunk hinges) ,,( I put some weather strip silicon and waiting for it to dry
    the only factor i can think of it either the end lighting closure, or the strain pipes that come from the edges of the sunroof under the headliner . . .
    Surfers Rent A Car
