Results 1 to 1 of 1
Thread: S13 Part Out RB20DET RB25DET RB26DET!
    Cool S13 Part Out RB20DET RB25DET RB26DET!
    My friends and I have accumulated a large amount of parts to sell. A lot of these parts are BRAND NEW and some are barely used to assist you with your swap for the S13 to RB20DET, RB25DET and RB26DET swap. Also if you need and any repair, maintenance or services, please don't hesitate to give us a call. I have a very knowledgeable group of import enthusiast backing me with the resources to get the job done.
    Call anytime and if I am not available please be patient and leave a detailed voicemail as I will get back to you as soon as possible.
    Uriah Cox
    404-781-7002
    [email protected]
    Parts List
    1) BRAND NEW! GodSpeed GT35 Turbo Journal Bearing balanced 500hp+ ***$300
    2) BRAND NEW! 1000cc injectors top feed. Fits RB20DET/RB26DET***$350
    3) BRAND NEW! Up to 1000hp fuel rail CNC cut***$85
    4) BRAND NEW! 90mm throttle body fits RB20DET***$80
    5) BRAND NEW! Adjustable Performance Cam Gears***$65
    6) BRAND NEW! Super Tech Valve Seals***$100
    7) BRAND NEW! Super Tech Valve Guides***$100
    8) BRAND NEW! 30psi wastegate ***$75
    9) ONLY 10mi Used! Tomei Cams intake/exhaust Fits RB20DET/RB25DET***$450
    10) BRAND NEW! RB20DET Skyline Torque Engine Damper***$65
    11) BRAND NEW! ARP head studs RB20DET***$100
    12) BRAND NEW! ARP rod bolts RB20DET***$100
    13) BRAND NEW! ARP main studs RB20DET***$100
    14) BRAND NEW! Tomei Oil Orifice RB20DET*** $15
    15) BRAND NEW! Front and Rear Main Seals RB20DET***$25
    16) GOOD USED! R32 RB20DET GTS-T Transmission***$200
    17) CUSTOM MADE! S13 to RB20DET swap Engine Harness***$150
    18) R32 RB20DET tuned ECU***$200
    19) GOOD USED! R32 RB20DET Stage 3 Clutch/ pressure plate/stock flywheel. Holds up to 500hp and 650ft pounds of torque. From the same company that makes Exedy Clutches***$300
    20) GOOD USED! RB20DET Engine Head***$125
    21) GOOD USED! RB20DET Bottom End Block***$100
    22) GOOD USED! S13 240sx Open End Differential***$70
    23) Top Hat Engine and Transmission Mounts for *** $170
    24) $1400 S13 to RB20DET Swap. Engine and transmission package deal. No turbo on this motor.
    $1400 includes:
    -engine
    -Complete wiring harness modified for te S13 to RB swap
    -transmission/Shifter
    -S13 to RB20 Top Hat Engine Mounts
    - Top Hat Tranny Mount
    -RB20 ecu
    -top mount turbo manifold or stock turbo manifold
    -38mm wastegate
    -jgy lightweight flywheel
    -clutch
    -ignitor chip
    -throttle body
    -alternator
    -powersteering pump
    - Intercooler
    -Blow Off Valve
    -Turbo Downpipe
    -(NO Turbo Come with this) So you are free to make that decision.
    Attached Thumbnails Attached Thumbnails -rb-jpg   -rb1-jpg   -rb2-jpg   -rb4-jpg
