Results 1 to 16 of 16
Thread: 1986 Porsche 951
    Sarcastic Asshole fivex684's Avatar
    Jefferson
    Default 1986 Porsche 951
    Just starting a build thread.
    The suspension on the car was SHOT!
    Did Weltmeister springs and Sachs struts. Got a great deal on the struts/shocks. Also lowered the rear as much as I could without re-indexing.
    Bakes are Zimmerman blanks, stainless lines, semi metallic pads and Ate Super Blue fluid.
    Installed Weltmeister Dme and Klr chips.
    Interior before, it was beat to hell and stained tan.
    After.
    Waiting for it to warm up before I finish painting the lower panels. Also need a black driver door panel.
    Stock airbox was busted. So put a ricer filter on it until I get a MAF conversion kit (Vitesse or Rogue).
    Also did a tune up. Plugs, wires, distributor and been replacing vac lines with silicone when I feel like it.
    ---------------------Engine:
    Tune up
    Weltmiester chips
    Silicone vac lines
    Suspension:
    Sachs struts/shocks
    Weltmiester 250lb springs
    Lowered rear as much as possible without re-indexing
    New sway bar bushings
    Brakes:
    Zimmerman blanks
    Stainless steel brake lines
    Ate super blue fluid
    Axxis Metal Master pads
    Chris / 97' Volvo 850R Wagon / 86' Porsche 944 Turbo
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    got any zoomed-out pics of the entire car?
    Jefferson
    Chattanooga, TN
    I've always liked those 944 line Porsches, maybe one day I'll get a turbo one. Be sure to get some of the Porsche twist wheels and all will be well
    how long have you owned it? That thing is cleannn
    Jefferson
    Since November. It's been a lot of work. With a good bit more ahead. Motor mounts and need to find a oil leak.
    Wow. That thing looks great!
    Did the previous owner live in gwinnett? And is the motor built? There used to be a clean one EXACTLY like this that came out to the park n ride/etc back in teh day. It was pretty fast too.
    Jefferson
    No. Got it from Elliot in Athens, its been in Florida all its life until this past summer.
    Columbus GA
    Quote Originally Posted by Matt300ZXT View Post
    x2.... Those wheels set it off.
    These wheels are amazing IMO, I'd keep them over the turbo twists.
    I want to have sex with this car.
    Jefferson
    The wheels look a bit better in the pics. The finish is starting to peel and a center cap is missing.
    edit: And the tires are dry rotted.
    love that body porsche
    Jefferson
    Got a set of 997 Turbo reps.
    18-235-40 front with 1.5" spacer
    18-285-30 rear with 2" spacer
    LAWRENCEVILLE
    Quote Originally Posted by RandomGuy View Post
    I know which one you're thinking of. That was a buddy of mines 944turbo model But it had a ls1 swap.
    Hella stock member!
    At Home
    Makes me miss my 944
