Results 1 to 17 of 17
Thread: Fully Built B16a Turbo Motor and Built GSR LSD Transmission -Alpharetta
    yeahhhh...... Nick Jeezy's Avatar
    Default Fully Built B16a Turbo Motor and Built GSR LSD Transmission -Alpharetta
    I have a full built b16a forsale.
    Bought off a customer that needed money and now i have no need for it.
    I would advise anyone to take the motor apart and check everything everything before putting it in a car. everything should be good but I did not assemble the motor.
    All Parts are NEW Unless stated.
    B16a
    Arias Pistons
    Eagle Rods
    ACL Race bearings
    ARP Rod bolts, main bolt, head studs
    Ported and Polished Head
    Skunk 2 Valve springs
    Skunk 2 Retainers
    Skunk 2 272 Cams
    1MM over valves
    AEM Adjustable timing Gears
    Cometic Metal Head gasket
    Mugen valve cover
    Greddy Timing belt
    Moroso Oil pan
    OEM Honda water pump
    Yamada oil pump
    Knock off t3/t4 Bottom Mount Manifold
    Schwitzer borg-warner 313102 T04B 62 trim turbo
    -3 oil feed line
    Tial 44mm Wastegate
    Competition Clutch light weight flywheel
    AEM fuel rail
    RC 550 Top Feed Injectors
    GSR LSD built Transmission
    ha-11-05 axles
    Price:5,000 OBO price drop 4,000
    I also have a few ECUs not sure which ones they are.
    If you have any questions feel free to give me a call
    678 548 9285
    Thanks
    Nick
    Wanting Boost! rsxappeal's Avatar
    part with GSR lsd tranny?
    not at the moment. If i decide to part I will let you know.
    Quote Originally Posted by Nick Jeezy View Post
    OK thanks..GLWS
    If you part I would like this (Competition Clutch light weight flywheel)
    Bump for this guy he is legit!
    ⎝⏠⏝⏠⎠ RandomGuy's Avatar
    Nick Jeezy is legit
    Thanks guys. still forsale
    4,000 come get it.
    Twan Jdm94Coupe's Avatar
    Fairburn
    Is it sleeved?
    no.
    Newnan
    Texted you about transmission. Let me know if you decide to part them up
    learn to english
    Jan 2013
    Can you run with no turbo, i have an austin mini that i am doing a
    honda swap on but the turbo wont fit
    Jan 2013
    Bump
    I Am, A Stunt Man
    if you decide to part out, I would love the valve cover!
    Like how timing belt arrows are going reverse engine rotation..
    Certified Gearhead Blaze the chemi's Avatar
    old thread, but do you still have the transmission for sale. Looking to replace my s4c. Thanks.
