Results 1 to 3 of 3
Thread: Parasitic Drain Test
    Nov 2012
    Decatur
    Exclamation Parasitic Drain Test
    Is there anyone in the metro atlanta area that has the equipment and know how to do a parasitic drain test??? LMK!!!!
    CL-S college guy
    2 low 4 common sense PTCDC5's Avatar
    Yes. However, it's simple to do and chances are your local AutoZone will be willing to do one for you. You will need a multimeter and utilize the ammeter function. The test is done in series with the battery of the vehicle. Depending on the vehicle, anywhere between 15-30mA is normal and healthy standby draw. While doing the test be sure that no hood or dome lights are on. Also, do not attempt to meter in parallel, you will blow a costly fuse
    I Am, A Stunt Man
