Thread: d15b7 swap
    barrow county
    Default d15b7 swap
    selling my d15b7 swap.
    this is out of scotsman's old 4door civic.
    tach shows 188k and 5 spd transmission mileage is unknown since it was swap automatic to 5spd.
    going to need engine harness ( im keeping it ) and vss, theres one there but the mount hole broke so sometimes it'll turn and speed wont be accurate. needs a new or cleaned idle air control valve.
    has new distrubitor,
    oem clutch and flywheel,
    ngk spark plugs,
    ngk spark plug wires
    pcv valve
    injector o-rings
    includes :
    axles,
    shift linkage but no shift nob
    4-2-1 aftermarket (wrapped) exhaust manifold
    long block
    transmission
    d15b7 ecu
    side motor mounts excluding the rear
    run strong. no leak or burn oil. block and transmission are very clean! ALMOST turn key swap, just no engine harness!
    I want 600 obo. call or text 678-963-8339
    locate in Barrow county. swap is still in car for the time being. Car is undergoing body work and repainting. Once its done, im taking swap out no matter if theres a buyer in line or not.
    NO PART OUT
    will update picture(s) once i find my camera. Dont mind the iphone picture.
    How much for just the longblock?
    My line of work
    www.internationaljets.com
    Scottish Scotsman's Avatar
    on the road to recovery
    let me get that header and those crx wheels!
    ttt
    barrow county
    sorry, no part out.
    making room for h or b-swap
    i'll bring the wheels over one of these days. been busy with work.
    Quote Originally Posted by Theycall_Metue View Post
    sorry, no part out.
    sounds good
