Results 1 to 39 of 39
Thread: FS: 4x100 Type-R brake upgrade, CL and S2k brake upgrade, GSR springs, d16 alternator
    Default FS: 4x100 Type-R brake upgrade, CL and S2k brake upgrade, GSR springs, d16 alternator
    Integra rear disc prop valve 40/40 - $30
    This is a 4040 proportioning valve from an Integra RS. This is for EG and EF civics when you do a rear disc conversion. In working shape.
    NSX front caliper brackets - $50
    This is a good, working pair of 28T brackets from a 95 Acura Legend GS. These are identical to the ones used on the 91-97 NSX front brakes. Great upgrade for the ITR or base model Legends if you are going to use the thicker discs. If you need these milled to fit a 4x100 setup, PM me.
    Integra Type-R Master Cylinder 1" - 55$
    This is a 1" MC pulled from a 2001 Integra type-R. Good replacement. Used for type-R brake upgrades on EKs; will bolt onto any 96-00 Civic, or 98-01 Integra.
    DX/S2000 brake upgrade - $375
    This is a for a front brake setup for all 88-00 Civics with the stock 9.5" brakes. Our steering knuckles have the tabs pulled in and don't work with a lot of other setups. However, now there is a great, lightweight option without even needing to change steering knuckles! This setup comes with S2000 calipers, modified brackets, pads, new rotors, and centering rings. It is a bolt on for all 88-00 Civics and all CRXs that have the 9.5" brakes, such as all DX, CX and LX models, CRX HF and Si, 92-93 Civic Si without ABS, and any 88-00 Civic or 90-01 Integra with Civic DX steering knuckles.
    This setup uses the lightweight S2000 calipers and 11" rotors and clears 15" wheels (and some 14s such as the RacingHart CPF, Volk TE-37 and TE28, Kosei K1s, and others but I don't know which.)
    4x100 Integra Type-R front brakes upgrade for Civic EXs and Integras - $310
    This is a set of the rare 4x100 front brakes for a Civic and Integra. This is a pair of ITR front calipers with the 23T brackets machined to fit the 4-lug knuckles. This also comes with a new pair of Prelude VTEC rotors. This was made by a former member of h-t.
    This brake upgrade is a behemoth of an upgrade over stock, using the big ass Type-R calipers with the 57mm pistons. The brackets were precision milled to fit. The rotors were redrilled with a milling machine to 4x100. This bolts onto any 90-01 Integra (exc 96 ITRs), and any 88-05 Civic EX, 99-00 Civic Si. This can fit any other 88-00 Civic if you get Integra or Civic EX knuckles, as their knuckles are different with regard to the caliper mounting point.
    You will want either a 15/16" or 1" master cylinder if you have a Civic.
    I have a pair of drilled/slotted rotors too, just ask.
    CL brake upgrade for 9.5" Civic Brakes - $395
    This is a brake upgrade for Hondas with 9.5" brakes such as 88-00 Civic DX and LX models, CRXs, 1st Gen Integras and 1st gen CRXs.
    This is a 11" brake upgrade for DX Civic knuckles. This setup uses Acura CL calipers, precision modification to the brackets to fit, 11" new rotors and hub-centric centering rings made from T6061 aluminum. This is THE best brake setup to clear a 15" diameter wheel. This uses a stronger caliper than the Type-R with a slightly larger pad. The setup comes with calipers, brackets, set of pads, new 11" discs and the centering rings. Its a bolt on to Honda/Acuras with the 9.5" stock brakes (or DA/DC Integras and EX civics with a DX civic knuckle swap.)
    This has a big piston, so a 15/16" MC at least is recommended.
    offers considered, PM me. Located on the north side of Atlanta.
    Feb 2010
    Default Brakes
    Any stock drilled rotors for a 2000 SI ?
    Thanks
    yeah, PMd
    whered ya go?
    ttt
    What was up with the rep points dodge?
    Fat 5s pictures are up
    ttt
    ttt
    ttt
    Got those drilled rotors for ya, don't know where you went to
    those brakes wont fit behind a 15" wheel will it?
    Quote Originally Posted by Sammich View Post
    Yes they will actually.
    the ITRs?! holy shit!!
    The ITR came with 15s, yeah it'll clear and they're pretty damn beefy.
    EM1 front LCAs for sale!
    updated
    updated
    ttt
    to the top...
    Aug 2012
    Interested in the DX/S2000 setup. You got any more of them? and what kind of MC upgrade if any would you recommend?
    Replied
    AKA "C@$HMONEY" vtecgsrguy's Avatar
    SOUTHSIDE
    Where ya located @? I might be interested in those lights & alt. Thanks!
    North side of atlanta, off the GA 400
    4040 valve for sale
    updated
    still alive!
    ttt
    Oct 2012
    Covington, Ga
    Where are you located I want that cluster if you still have it lmk 7705499786 text only thanks
    texted...and no reply from in a few days
    Alpharetta/Duluth
    The Civic LCA's wont with a DC2 teg, right?
    I am interested in some front brakes for my GSR though.... PM me your number.
    PMd. Also, Integra MC for sale.
    del sol console for sale
    ttt
    updated
    glove box sold
    checked and updated
    up we goin
    more stuff to come
