Thread: FS: H22 sleeved block, cams, rods, etc....
    Mar 2012
    Default FS: H22 sleeved block, cams, rods, etc....
    All pics are hyperlinks, click on a pic to see the larger version!
    All prices are OBO. Parts are located in Roswell, willing to meet for the larger parts. Only possible trades would be for 8th gen Si parts.
    Best way to contact is email at [email protected]
    My name is Sean
    Darton sleeved H22A1 block. This is a closed deck block with 50mm main journals. The sleeves are the Darton flanged press in sleeves. Block is freshly decked and bored to 88mm. Was clearance for cast pistons mistakenly so there should be enough room to run it at 88mm with a fresh hone.
    400obo
    H22 head. The ports have been bowl blended by hand. Needs a valve job. Complete with cams.
    100obo
    APR H22 head studs. Torqued once, never ran.
    100obo
    H22 50mm mains crank. Already micropolished.
    100obo
    H22 eagle rods. Used but the big ends have been honed and are all in spec.
    200obo
    H22 VtecKidd RMF replica header. New and unused. Has a very slight dent in the exhaust flange as seen in pics.
    300obo
    88mm Wiseco pistons. 11.5 comp ratio. OK shape but useable.
    150obo
    H22 supertech valve springs. Installed but never ran. These are the 80lb seat pressure version.
    SOLD
    H22 full gasket set minus head gasket and valve stem seals.
    20obo
    H22 skunk2 stage 3 cams and skunk2 cam gears.
    SOLD
    GMB H22 water pump. New.
    30obo
    Ebay B series ramhorn. Has been rewelded and pressure tested.
    50obo
    Mar 2012
    Bump for header added
    Mar 2012
    Bump, radiator and fuel pump sold.
    SOUTHERN SPEED
    macon ga
    can you text picture of block and pistons to my phone . Thanks 478-808-9122
    SOUTHERN SPEED
    macon ga
    are the cams pro series or stage series ? thanks.
    Mar 2012
    Bump, pics sent.
    The cams are Tuner series.
    Mar 2012
    Bump. Cams, cam gears, and valvesprings sold.
    Mar 2012
    Block and pistons pending
Tags for this Thread
