So I picked up my old integra. She was on cinder blocks and cob webbed, transmission wouldnt go into third and barely went into 5th, battery dead and bolt hole for the timing tensioner was stripped along with many other issues..
cleaned up the bay real quick, still pretty bad
...teardown begins
Charge pipe, FYI real reason for rebuild, after I thought I might be able to get away with changing the oil and putting the timing belt on...WRONG. The charge pipe had been rubbing for some time on the trans mount and it must have sucked some shavings in, because 2 cylinders had nice scars creating a huge cloud of smoke whenever I started her.
I decided to change a few things Ill let the pics tell the rest.
Freshness with a s4c trans with an ls 5th gear this time.
And here is a couple quick pics of the beautiful all trac I found in alabama. Completely stock, has a spun bearing in the block and an issue with the fuel pump getting power, but for the condition its in, it is remarkable. It currently sits under a cover until I can afford to rebuild here the right way..
Hope you enjoyed the pics. BTW im still in need of a 98-01 front bumper for the integra.
