Results 1 to 5 of 5
Thread: 1991 Acura Integra GS Door Not Opening, help!
    Angry 1991 Acura Integra GS Door Not Opening, help!
    SO my car dOor doesn't open. I forced the inside of the door open to get it to manually unhook it from latch. I end up breaking it, I buy another door at pullapart, worked fine for 3 tries then it stoppe opening. Now I have a red fawking door on my black car and I'm at the same place. Is there a fuse fOr the door latch opener thing? Its the GS version so power options of course.
    1991 Acura Integra
    1998 Toyota Corolla
    Apr 2012
    McDonough
    My father had this issue with his 1991 civic si. In his car, his seat belt assembly on the driver side was the main issue. I am not completely sure about integras since I never had one, but it may be something related to the electronics in the seat belts (if you have the auto seat belts that retract) that is causing the door to lock and not reopen.
    I apologize if this sounds confusing, I will give my father a call in the morning, and from there I will explain exactly what he did to fix the issue.
    How did he fix it?
    Thanks for input.
    1991 Acura Integra
    1998 Toyota Corolla
    I hate going thru the passenger side.
    1991 Acura Integra
    1998 Toyota Corolla
    Apr 2012
    McDonough
    I spoke with my father, and his situation was a little different (his battery kept dying due to the door and the seat belt). What he said he did was disconnect the door lock from the seat belt and that should help. If not, try disconnecting the seat belt plug under the seat. I hope that this is helpful.
