Results 1 to 3 of 3
Thread: HELP! 96 Civic EX (dizzy problem)
    IA MEMBER jdm_eg8's Avatar
    Default HELP! 96 Civic EX (dizzy problem)
    Okay so yesterday I was tinkering around on my 96' civic ex coupe with a perfect running d16y8 sohc vtec! Problem is I noticed 2 bolts missing on my dizzy cap & removed the cap to get to the rear bolt so I could start to thread it back through so it wouldn't slip out of my hand & be gone, lol. So after starting to put it back together I noticed it wasn't sealing up right, thought it could be just a rear bolt not being tightened all the way. Well long story short I tried starting the car & got absolutely nothing, no dash lights or cd player turning on at time of turning key & no fire/spark/fuel pump cutting on or anything at all. Only thing it does is make the key chime & I can turn my headlights on! So I started inspecting the dizzy cap & remived to see if any wires could have been keeping it from sitting flush with dizzy housing & low & be hold I have 2 wires that were cut in half! The black/yellow & solid blueish green wire! So I tried connecting them & got the same thing, no dash lights, cd player no spark/fire/no fuel pump turing on, no nothing! Weird as hell wires are reconnected strong & I checked my fuses for starter solenoid & ignition coil & fuel pump inside fuse panel located under dash & nothing & don't get it! Need some help here asap!
    Kinda lame IRL isa2o3's Avatar
    Check to see if the spring on the coil popped out when you took the cap off.
    Quote Originally Posted by isa2o3 View Post
    No worries, it was a $5 fix thanks to my family mechanic! Stupid 40A fuse under hood blew! My splices worked for my dizzy! Up & Dailying again
