Thread: Parish 300+hp h2b part out
    Yea I drive a Neon! justnprsh07's Avatar
    Aug 2009
    columbus
    Default Parish 300+hp h2b part out
    Hate to do it but decided to part my ways with the import scene to spend more time with the family and put my money in better places.
    Everything has one dyno secession and 4 track passes on it. This h2b setup made over 300hp easily.
    INEED THIS STUFF GONE!!!! SO MAKE OFFERS!!!
    More you buy the cheaper it gets. text me at 7065877278 willing to do some trading for a 450+cc racing style quad cars trucks etc.
    LIMITED TIME PRICE INCLUDES SHIPPING!!!!!!
    [IMG][/IMG]
    text for pictures of anything you would like to see... just to many pictures to post
    chassis eg coupe, lexan windows, 14 point cage ready for recertification, willie barr, parachute, one piece axle, kirkey seat, wiring harness, switch panel, fire suppressant system, custom one piece front, gauge panel, aluminum dash, skunk2 pro front suspension, and more $2500
    kinsler 62mm itbs with throttle cable bracket,tps mount and sensor, and vacuum canister so u can run map base $1600
    jack meyers drag header i just paid $1400 selling for $800
    exospeed star 8s 24.5x9x 13s and skinnies $sold
    Qsd h2b kit $sold
    Bseries axles and intermediate shaft $100
    competition stg5 unsprung 4puc "needs new rivets" $100
    Aluminum flywheel $100
    drop engineering green motor mounts $150
    3 h22 90mm 15:1 pistons $100
    h22 bme aluminum rods $350
    kaizen speed balance shaft eliminator $sold
    kaizen speed timing belt tensioner $sold
    fluidampner harmonic balancer $200
    h22 arp head studs $sold
    timing belt $sold
    h23 crank 50mm $100
    Bensen 90mm sleeved block $500
    rlz ported head with extra dome work $800
    supertech springs and retainers $sold
    Ferrea roller rocker setup with cams and block off plate $900
    Valve cover with catch can setup $sold
    dizzy $50
    misimoto radiator with fans and hoses $150
    b16 trans with carbon syncros and spool $600 "can replace spool w/ stock diff"
    2gal fuel cell to mount in battery location $100
    walbro inline pump $50
    rc 1000cc kseries injectors $200
    hondata s300 $sold
    carbon plug cover $sold
    crower timing gears $50
    msd blaster coil and sci box $75
    nos pro fogger direct port nitrous kit 150-500 shot $300
    Omni 70mm tb $sold
    Braided brake lines $sold
    Front suspension with spindles, subframe, and manual steering rack $100
    pedals for manual swap $40
    Prodrive b series spool $150
    Carbon Hood with all under bracing cut out for eg $80
    eg sub frame brace $sold
    Autometer tachometer with shift light $30
    K20 pistons Brand New!! never even mocked up $225
    AEM Fuel Rail h22 $50
    Wildwood Pull slave cylinder brand new $50
    Aem H22 pulleys $20
    SRT4 stock turbo $100
    Radiator Fan $20
    Eg hatch carbon roof $300
    EG custom bumper with carbon lip $100
    Intercooler pipe for k series with 50mm tial flange and iat sensor bolt in plate $25
    aem external regulator $50
    blox external regulator $30
    im sure there is alot more that i will post as i notice im missing and i have tons of stock stuff if you need anything just text me!!!
    [SIGPIC][/SIGPIC]
