Thread: Dodge SRT-4 Neon Parts For Sale. Everything Must Go. No Trades.
    Similac Fed [Reckless]'s Avatar
    Default Dodge SRT-4 Neon Parts For Sale. Everything Must Go. No Trades.
    I traded in my '03 SRT-4 yesterday for something more practical and reliable. All the engine parts, components, and accessories have either 0-3,000 miles on them. The car was setup on the S3 mods at 3,000 miles and when I let the car go it had 65,800 on the odometer.
    VIN:1B3ES66S63D206045
    Car was traded in at Cherokee Dodge in Canton, GA. Not sure if the car will be auctioned off or will be sold on the lot for anyone interested.
    Enigne Parts/Accessories:
    Mopar Carbon Fiber Boost Guage with all connections, install instuctions. Never Used..... $100 obo
    Mopar 3D Euro Tail Lights (03-05 Neon). Seals are in tack. No damage to lenses...... $100 obo
    Mopar Stage 2 PCM. This will need to be flashed to your VIN # to work..... $175 obo
    Stock SRT-4 TD04 turbo with manifold housing and wastegate. Wastegate may be stage 1 or stock. Both will come with this if purchased. Turbo has at most 3,000 miles with absolutely no play in the shaft.....$325 obo
    Stock Purple Gen 1 SRT Injectors (4). Again barely used at the most 1,000 miles...... $60 obo
    Stock 04-05 55lb injectors (4). Barely used with at most 1,000 miles.....$75 obo
    Set of Stock axles... no miles on them (1 is still in its original banded package)..... $60 obo
    OEM Fuel Pump Housing w/ level..... $60 obo
    OEM SRT-4 Valve Cover...Immaculate condition.... $100 obo
    OEM Struts and Springs (4) with 3000 miles. No leaks on strut rods 2 pictured......$50 obo
    Wheels and Tires:
    (2) BFGoodrich Drag Radials 225/45/R17. Tread is at the wear bar on both.....$25
    (4) Stock 17in Cross hairs. Tires need to be replaced......SOLD
    (25) OEM Lug Nuts..... $20
    Mssg me for my Cell phone #
    If you use kik s/n is justineffyou. This is the quickest way to get a hold of me.
    Images are sized small for easy viewing. Original larger images available upon request
    I live in Marietta and can drive but may require to meet up somewhere half way if you're coming out from somewhere far
    Happy buying
    Certified Gearhead l Gizzy l's Avatar
    Jun 2010
    Dallas, GA
    PM'd
    Crosshairs pending sale
    Crosshairs sold. Bump.
    Jun 2010
    Dallas, GA
    talked to my brother, he loves the wheels btw
    He said the stage 2 PCM IS able to be retuned, but he would have to get bigger injectors.
    i'll let him know
    Awesome. Yea I completely forgot to look that up sun. He should be able to get the injectors through Modern Performance
    Morning bump
