Results 1 to 1 of 1
Thread: FS: Brand New wiseco B-serie81.50mm pistons,b18c1 GSR timing belt oem honda NEW
    Stupid fruity Swagg
    On Earth
    Default FS: Brand New wiseco B-serie81.50mm pistons,b18c1 GSR timing belt oem honda NEW
    text or leave message at 404-952-5068
    I have a bmw and have no need for the parts anymore
    up for sale are
    Brand new b18c1 Gsr timing belt OEM honda never used still in plastic 50bucs firm picked up located riverdale
    Brand new wiseco b-series 81.50mm pistons brand new never used still in box with wrist pins and all of the pistons rings also brand new
    most places sell them for around 475-550, get yours brand new quicker for 375 FIRM
    k593m815 is the part number compression ranges from 12.5 to 13.2 to 1 depending on the head application and etc. so they are High compression pistons
    Brand:
    Wiseco
    Manufacturer's Part Number:
    K593M815
    Part Type:
    Piston and Ring Kits
    Product Line:
    Wiseco Sport Compact Piston and Ring Kits
    Summit Racing Part Number:
    WIS-K593M815
    Bore (in):
    3.209 in.
    Bore (mm):
    81.500mm
    Piston Style:
    Dome, with no valve reliefs
    Piston Material:
    Forged aluminum
    Compression Distance (in):
    1.181 in.
    Piston Head Volume (cc):
    -8.25cc
    Wrist Pin Style:
    Press-fit or floating
    Pin Diameter (in):
    0.827 in.
    Gapless:
    No
    File Fit:
    No
    Top Ring Thickness:
    1.0mm
    Top Ring Material:
    Steel
    Top Ring Facing Material:
    Gas nitrided
    Second Ring Thickness:
    1.2mm
    Second Ring Material:
    Cast iron
    Second Ring Facing Material:
    Phosphate coated
    Oil Ring Thickness:
    2.8mm
    Oil Ring Material:
    Stainless steel
    Oil Ring Tension:
    Standard
    Attached Thumbnails Attached Thumbnails -imag0141-copy-jpg   -33763230085_medium-jpg
