Thread: my 93 vtech civic has no spark with new dizzy
    Dec 2010
    Default my 93 vtech civic has no spark with new dizzy
    Ok so i got a new distributor and put it on the car but,even with the new one it still has no
    spark so now i'm stuck with no other options on what else i should check in order
    to get this car running again. I even change the old ecu because the old one did not run my fuel pump,but the new one does
    but still no spark. the motor turns but won't start up.
    Certified Gearhead oreign's Avatar
    May 2011
    main relay?
    somewhere, GA
    Does it have dial tone??
    '82 TE72 SR5 Sport Coupe
    3tc
    Northwest Georgia
    LoL
    Dec 2010
    the main relay in the car seems to be working well right now, or is that it is working but not as good,is that possible. man I really need to get this
    thing running so i can get to work ugh. I would like to know what else will cause this problem to happen
    Certified Gearhead johnny_d's Avatar
    Sep 2008
    southside
    Spray some starting fluid through throttle body if it turns on then you sir have a fuel problem maybe injectors, main relay, fuel pump. If you try to start it and pull one coil out put it near a bolt and no spark,, maybe defective dizzy, check ground, make sure all wiring is good no cuts and check if your computer is blinking red ,,if it is bad computer
    '92 EG Hatch Sunkenkarma's Avatar
    Flowery Branch , Ga
    Had this same thing happen to me, changed out the main relay, nothing, make sure you hear your fuel pump priming when you turn the key, it turned out to be the fuel pump fuse under the hood.
    [/URL]
